Question about Dell Latitude D620 Notebook
Dell D620 Won't POST
I was using my Dell D620 until this afternoon, when I ran into what looks to be a serious problem. When I now attempt to power on the computer, The power light comes on, the three LED's (num lock, caps lock, scroll lock) flash on for a second or two and then go off, and nothing further happens.
I have been all over the Dell Knowledge base on their support web site, and have run through all of the end-user diagnotics that I could find. I found an article that describes how to generate LED diagnostic codes holding the key down for a second or so as I turn the computer on. When I do that, the LED's show the following: NumLoc constantly flashes green (and will do so for as long as I choose to leave the power on), while the CapsLoc and ScrollLoc are constant green (no flashing). I haven't been able to find an answer as to what this combination indicates, although I am tempted to say that it's video related. This Dell D620 has the Nvidea graphics chip.
I am looking for a definition of the diagnostic code described above, and some direction on how to fix the problem. Before you ask, you should know that the computer is out of warranty.
Thanks in advance for your assistance.
  • 2 more comments
  • Anonymous Jan 13, 2009
    Tried to upgrade the memory from 2GB to 4GB on a D620 ... now the machine just gives an on-flashing-flashing error code on the diagnostic LED. Reinstalling the old memory doesn't help. I hope I didn't fry the motherboard with a stray jolt of static electricity.
  • Anonymous Jan 17, 2009
    I have exactly the same problem
  • Anonymous Jan 27, 2009
    same problem here when upgrading ram. have another go at inserting the memory sticks. they will push into the slots another 1-2mm than when you first inserted them.
  • mjatl Mar 06, 2009
    The symptoms of my machine are the same as described. One morning, I opened up the computer to discover that the screen will not display anything. The computer will shut down immediately when power is pushed. Flash codes indicate that it has a CPU or processor failure (flashing on on). The results are the same with or without the CMOS battery installed. At one point, I tried different memory combinations and did get a flash code to indicate that memory was missing when it was not installed properly. I plan to try reading the HD in an external case next. There are many posts about an NVIDIA problem, though I haven't found details enough to know whether this might be related. This Dell D620 is almost exactly 2 yrs old.
If two of the three leds are flashing (the one on the left stays solid and the two other blink) then this is a no memory error and its likely the memory is not seated properly.
Remove the memory from under the keyboard and try one DIMM at a time in the slot on the back of the computer. Once the PC is booting again reintroduce the DIMM under the keyboard. Like the previous poster indicated the memory needs to be well seated.
Worked for me...
Posted on May 30, 2009
  • asif Aug 31, 2013
    worked
I upgraded ram on a D630 and when I powered the system back on, the caps lock light flashed 45 times and then died. Turns out I hadn't pushed hard enough seating the memory modules (aside, one is under the keyboard--to remove the keyboard, you have to pry off the hinge guard, the plastic strip across the top of the keyboard where the power and sound buttons and lock lights are. Do it carefully--a manual says use a plastic scribe--cuz you don't want to break the plastic). The modules should be pushed in far enough so that the tabs on the ends of the clips fit into the notch on the memory stick. I thought I'd pushed plenty hard--wrong!
Posted on May 02, 2009
    Guru:
  • 859 Answers
Rather than chase down a ghost, try resetting the system by removing your external power, and removing your battery. Leave it out for a while then reinsert it and add external power later. Boot up and enter system setup. While in setup choose to set "System Defaults" and then exit setup and restart. All should be okay after that.
If that doesn't do it, remove the internal battery connector for few minutes while external power and the battery is out. There are holes in the bottom that point to the keyboard screws, be careful to lift the keyboard easily. You'll see the internal battery near the back and a connector to the board. Remove that connector carefully and lightly. Once off, leave it off for awhile. Reconnect reset your keyboard into the tray add power and battery and reboot into the system setup screens to reset the date and time and other power options etc.
In most cases, the laptop just gets glitched and confused and these lights will flash for a meaningless reason. Resetting the bios as described above usually works. I repeat usually works
Unfortunately, if that doesn't do it, you'll need to phone Dell Support and suffer through that experience.
There are mini PCI cards in laptops and yours may be a graphics card but usually they're modems and network adapters. If you have a graphics card remove it and reinsert it. This works a lot of the time and may do it for you as your instincts may be correct.
In the long run, searching for a list of code descriptions for flashing lights is an endless easter egg hunt as they're reserved for Dell internal repair purposes.
Ultimately you may just want to replace the entire unit by shopping on Ebay and picking one up for around $600.
I know this isn't much help but I gotta tell you what experience has proven to most of us and ask you to try the above suggestions and if that fails consider that you may now own a dead laptop.. although I rather doubt it.
Regards,
Worldvet
Posted on May 15, 2008
I just spoke to Dell Support about this very issue. They told me that the processor is bad.
Posted on Dec 07, 2008
My D620 has just started doing the same thing. The flash codes are very relevant and they do mean something. I suspect it's memory or video related as the LCD doesn't come on nor my external monitor. The CPU is functional (pressing the power and getting an immediate power off instead of waiting 5 seconds means the CPU is functional).
I do have the NVidia card which is on the list of cards that NVidia screwed up with and which are failing. See: http://direct2dell.com/one2one/archive/2008/08/18/nvidia-gpu-update-dell-to-offer-warranty-enhancement-to-all-affected-customers-worldwide.aspx
If you're issue is video related with the NVidia card, you should get another year of free warrenty.
I'll let you know what happens with mine as it should be under warrenty.
Posted on Sep 10, 2008
I had a similar problem. I had a faulty memory chip.
Posted on Mar 20, 2011
Hey, all i just got the same issue as described above. i've deinstalled every component and tried to minimize the system, but it still won't up, blank display, i've noticed the GPU and CPU chip is getting hotter while i turned on the power, dose that mean the BOTH are functioning well???
Posted on Aug 15, 2010
3 Suggested Answers
SOURCE: Dell Vostro 1510 laptop.NUM lock
Go to dell site and check what LED flashing means.This points to the problem.good luck
Posted on Apr 13, 2011
  • 998 Answers
SOURCE: Holding down the Func key
If your laptop won't run the diagnostics ( Holding down the Func key while powering up ) then you need to try and isolate the problem. Something is preventing the laptop from performing POST ( power-on self diagnostics ). Try removing the hard disk drive, memory modules, external USB devices.
Posted on Sep 06, 2011
How to download free 9.0 graphics for dell laptops
Hello, your question is a bit confusing. By 9.0, exactly what you mean? Do you mean DirectX 9.0? If so, yes, you can visit microsoft.com, downloads page for a list of DirectX 9.0 or even later drivers which will run on your system and will update your current DirectX.
But if you are looking for graphics, go to this page:
http://www.dell.com/support/drivers/us/en/04/Product/latitude-d620
and hit ANALYZE SYSTEM FOR UPDATES.
Hope this helps, if not please contact me why not :) Thanks
Apr 04, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
How to use builtin camera in dell latitude d620
In control panel look for camera and open from there.
May 26, 2012 | Dell Latitude D620 (D620-rfb1.6) PC...
Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
Two possible causes for flashing Amber battery light.
1) Your battery won't charge and needs to be replaced.
2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
Oct 20, 2011 | Dell Latitude D620 Notebook
How can i use my webcam in my notbook dell latitude d620, n how could i got the driver?????
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
download driver at link above
after download double click installer then follow the instruction until finish, and you got camera
Mar 10, 2011 | Dell Latitude D620 Notebook
I have a dell latitude d620 with a failed motherboard,but i have also a dell d600 with a failed dispay,can i put the motherboard of dell d600 to d620?
Hello
No dear the both motherboards are altogether different from each other, you need the identical motherboard as d620 have.
Good Luck
Dec 20, 2010 | Dell for Latitude D620 Motherboard
How to restore my D620 to factory settings without a CD?
Hello there!
Well its impossible to restore any of todays laptops without their factory os dvd/cd. You could setup new operative system and make your laptop simmilar to what it was on factory settings, or you can search dell to send you that same cd/dvd on your post mail to your house.
I suggest you read http://www.dell.com/ and contact them in order to solve your problem. Hope i helped you! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Dell Latitude D620 Notebook
Bios won't load when attached to D-Dock. Will load when not attached. Ran diagnostics when not attached and the the 3rd cache is missing. When I press o.k. it restarts and runs fine off the d dock but...
if you have access to another D-Series system, see if it will work on the Dock. If a Known Good System will not post on the dock, the dock is bad. If it does boot, then the Motherboard connector on your D620 is bad and motherboard will need replacement.
Nov 07, 2009 | Dell Latitude D620 Notebook
Dell latitude d620. top on Shift key has fallen off. How do I pop it back on?
the cap will fasten back on by rolling your finger across the cap from one side to the other while firly pressing down, it will snap back on.
Oct 04, 2009 | Dell Latitude D620 Notebook
Is any cheap battery for laptop d620
Hi - i've ran a D620 now running a D630 and yes the battery life is extremely poor even when the battery is new.
The option above will give you extra - you can also buy a moduler battery that will fit into the CDROM port which will give you even more!
http://www.google.co.uk/products?hl=en&q=d620%20modular%20battery&cr=countryUK%7CcountryGB&um=1&ie=UTF-8&sa=N&tab=wf
or ebay is your best bet...
Dec 31, 2008 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
15,982 people viewed this question
Alun Cox
