Question about Gaggia Titanium Espresso Machine
Gaggia titanium machine, display says dregdrawer missing, even when I've clicked drawer back in place after cleaning it...
  • 1,089 Answers
Hi
Either your tab is broken on the back of your dredge drawer or your microswitch has been moved from its correct position. There should be a tab on the back of the dredge drawer. If not you need a new dredge drawer.
Posted on Sep 13, 2010
Coffee grounds (unused) dropped into dregdrawer tray
try to make the grinder position on 2.
And where exactly is the unused coffee-in the drawer or under the brew unit? Did you try to wash the brew unit with water-fill a box with hot water and put it into box. Leave it all night and in the morning just clean on the water and dry it.
Let me know what is result when you done it!
Apr 14, 2015 | Gaggia Titanium Espresso Machine
Dregdrawer missing message won't go away
The dregdrawer is connected to a button/switch inside the machine.
- Switch broken.
- dregdrawer wrongly placed.
- dregdrawer is broken. (projection which goes into te machine is broken)
Sep 29, 2014 | Gaggia Titanium Espresso Machine
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
Dregdrawer full
Check the back of the drain tray make sure there are no grinds. Then we will have to test the micro switches, remove the drain tray and dregs drawer, insert tray without the drawer, to see if you get an error. A more complicated way is to have the door open place tray minus drawer in machine, then using a small stray or plastic knife, activate the microswitches.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
Jan 24, 2010 | Gaggia Syncrony Espresso Machine
Gaggia syncrony compact digital - DREGDRAWER MISSING
the thing that dropped out was part of the micro switch for the dregs draw. Yes you can use the machine with the piece that you put in there, at some time you might consider just replacing the micro switch.
Sep 24, 2008 | Gaggia Titanium Espresso Machine
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
Dregdrawer full
drain machine, turn off power , get vacuum cleaner nozzle into drawer slot (make sure its dry or u'll have to post a repair for vacuum cleaner repair) remove all deposits for chamber , shake and bang machine to lossen deposits. if drawer has metal clips or something that looks like sensors (does not have to have wires attached to be a sensor) clean !
Feb 02, 2008 | Gaggia Syncrony Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
489 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
