Question about Toshiba Satellite A35-S159 Notebook
WIN XP won't start
Hi, I was running an accounting program on WIN XP and it froze, so I chose to restart the machine without closing the program first, now, the OS won't boot and all I'm getting is a message after the welcome screen that says "windows could not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM
You can attempt to repair this file by starting windows setup using the original setup CD-ROM
Select 'r' at the first screen to start repair"
I pressed 'r' but it will take back to the same message and the machine sounds like it is trying to start from the CD-ROM, I checked the BIOS and HDD is the first one on the list to boot, I also tried from the Advance Options menu the different options, Safe Mode, Last Good Known Configuration etc. but they all take me to the same message mentioned above.
I have the recovery CD, but reinstalling the OS that way will erase all the important data. Is there a way to reinstall the OS without loosing my files? Can You help me please, Thanks
  • 1 more comment
  • Dickk May 29, 2008
    System locked up so I tried to restart it and a sysconfig/setup message appeared. I do not have any of the program discs because this unit was given to me by my son who also does not have them.
    Should I talk to Toshiba first or should I just take it to the geek squad and let them figure it out?
    Dickk
  • mitike777 Feb 05, 2009
    i have a similar problem need to repair window xp, can i boot the cd from the OS or i have to boot from bios?
    same problem
    ca i boot the cd from the PS or i have to boot it from bios
  • 242 Answers
You have to set the BIOS to boot from CD-ROM, so it should be the first one. Then from the installation screen you have to press r to try and repair your windows installation. This should work without losing your data.
Posted on May 15, 2008
2 Suggested Answers
jepito
  • 216 Answers
SOURCE: \windows\system32\config\system is missing or
boot to a operating syatem disc and the first repair option press r you will see a black screen and a prompt like c:\ ect ect ...
type chkdsk /r press enter
make sure to put a space between the k and /
when it finishes type fixboot and press enter
if that does not correct it you must do a operating system repair
Posted on Dec 29, 2009
Drivers HP scanjet 4400c for windows 7
This worked for me:
Do NOT connect scanner before these first few steps
1. Download & save win xp drivers from HP website: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=28447&prodTypeId=15179&prodSeriesId=28441&swLang=8&taskId=135&swEnvOID=228
The 63.4mb file is the only one you'll need
2. Right-click on the saved file and go to its properties. Under the compatibility tab, set the file to run with win xp service pack 3. Apply changes and close properties dialogue.
3. Right click on the same file and choose 'run as administrator'. Accept any windows prompts that may appear and let the program & drivers install.
4. Once the software has finished installing, connect the scanner to your computer (via USB) and turn the scanner on.
5. Restart the computer without unplugging or turning the scanner off.
6. Your scanner should now work fine with the HP Precisionscan Pro utility.
Oct 31, 2011 | HP Scanjet 4400c Flatbed Scanner
As soon as i turn my computer on it asks for a password before even loading completely how do i get it unlocked with out knowing the password
if your using win Xp wile booting keep hitting F8 when the screen comes up for what mode you want to boot into chose safe mood without network support when it finished loading go to user accounts their should show a list like admin and guest click admin and then chose remove password then close all windows and start close turn off computer then restart allow it to restart and it should bypass the password do this steps for all your accounts like guest ect you should be able to go right to windows hope this helps
Aug 28, 2010 | Computers & Internet
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
Win xp error code 0 x 80090006 after win update
Some times this problem occurs.You dont worry.you will update after some days.Now you can do the bellow steps
start->all programs->accessories->system tools->system restore->restore my computer earliar time ->
then choose the best cheak point .then ok->close.
wait 10 to 20 minutes. your system automaticaly restored in previous state.(Before Updated state).
Note: You must chose the date before update the windows.(Cheakpoint)
Feb 13, 2010 | Microsoft Windows XP Professional
I'm getting an error that says MFC application has stopped working. It's coming up when I open my PED-Basic. I have deleted the program and reinstalled but i still keep getting this message. When I...
if you have win 7 or vista on your laptop .. the program may be written for win xp .. if so, you can check to see if ugraded software is available from brother for your operating system .. .. or you can load your present software using windows " Compaaibillity Mode" chose XP or whatever operating system the brother software was written for .. right click on your program loader on your disk (setup or whateve) . then select "compatability mode"
Jan 27, 2010 | Brother SE-270D Computerized Sewing...
Just bought cant get into because saying needs user name and password hoe do i overcome to get into laptop
If you are using win XP try to restart the machine then as soon as the machine restarts press F8 on the keybaord the machine will give you a few option choose start in safe mode the machine will start up then go into the control panel then look for user accounts then choose the account then say click change account take out the username and the password and click ok then restart the machine this sould work
Sep 25, 2009 | Toshiba Satellite L25-S119 Notebook
Software runs until I power down at next power up software dies.
I would suggest purchasing the version of the Mavis Beacon Teaches Typing v 1.5. It's compatible with Windows XP. I've also looked at the software description and you are able to select the age group of the typing test.
However, if some reason you have to continue with the same version. What error message do you recieve?
Thank You, Raphael
Jan 21, 2009 | Mindscape Mavis Beacon Typing for Kids...
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
    • Load Startup Items
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
I need 2 restart comp after running graphic apps
Sounds like your system is not freeing the RAM after using the program. You can manually close them by going into the processes section of your task manager or rebooting. Best solution would be to try upgrading system RAM and see if more RAM fixes the problem. Hope this helps.
Sep 22, 2008 | HP Quadro4 980 XGL (128 MB) AGP Graphic...
Toshiba Satellite A35-S159 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
