Question about DameWare MINI REMOTE CTRL 10U (DMRCCV-10) for PC
I get error 1920 (No permission to start system services) even if I belong to the administrators group
Access local disc C
You may have to remove it from the domain and deleted the object in AD. Then re-add it. You locked out all trusted domain users, and possibly including yourself.
You also try logging in locally and adding the domain account to the Administrators group. You need rights for all this, so you may have to have a domain administrator do this for you.
May 01, 2013 | Computers & Internet
Tip
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
Those users running genuine version of Windows 7 provided with their hardware platform reported that immediately after log on they were presented with following error message. “Windows is not genuine. Your computer might not be running a counterfeit copy of Windows. 0×80070005.”
Some other symptoms of associated with this issue are,
The computer desktop background is black, and you receive the following error message on the bottom right corner of the screen:
“This copy of Windows is not genuine”
You receive the following error message when you view the System Properties: (Control Panel / System and Security / System)
“You must activate today. Activate Windows now”
If you try to use slmgr.vbs /dlv to view the licensing status, you receive the following message:
Error: 0×80070005 Access denied: the requested action requires elevated privileges
Microsoft is fully aware of this issue and provided following explanation for the issue,
There is a lack of permissions in the registry key HKU\S-1-5-20. The Network Service account must have full control and read permissions over that registry key.
This situation may be the result of applying a Plug and Play Group Policy object (GPO).
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy
1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on Jul 15, 2010 | Computers & Internet
Tip
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
sc sdshow plugplay
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
on May 19, 2010 | Computers & Internet
Error 1920 while installing seagate dashboard on windows xp
This problem is related to RTCHDomain services. If you add admins to the services you can easily solve this problem. To visit the detailed explanation and step by step solution visit the following link - http://www.techyv.com/questions/error-1920-service-%E2%80%98office-software-protection-platform-failed-start
Hope it helps
Apr 05, 2013 | Seagate Backup Plus 1 TB USB 3.0 Portable...
I get an error that says "insufficient privlages; you must be an administrator to run this application for the first time
To prevent this error from occurring, make sure the folder location into which you are installing has Full Control permissions for either the Everyone group or the SYSTEM group. Check the permissions for the parent folders because the permissions on these folders may also cause this problem.
or try open it as an
administrator
Jan 23, 2013 | Aspyr 1701 A.D. for Windows, Mac
How can i fix error 1404 on microsoft office 1010
  1. If you receive the "Error 1404" error message, remove the registry subkey that is referred to in the error message. To do this, follow these steps:
    Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
    1. Click Start, click Run, type regedt32 in the Open box, and then click OK.
    2. Locate the registry subkey that is referred to in the "Error 1404" error message. Make sure that you locate the exact registry subkey that is specified in the error message.
    3. Right-click the registry subkey that you located in the previous step, and then click Permissions.
    4. Under Group or user names, click Administrators, click to select the Full Control check box under Allow, and then click OK.
    5. Right-click the registry subkey, and then click Delete.
      When you are prompted to confirm the deletion, click Yes.
  2. Start Windows Explorer, and then locate the drive:\Winnt\Installer folder. In this folder location, drive is the hard disk where Windows is installed.
    Note This folder may be hidden. If the drive:\Winnt\Installer folder does not appear in Windows Explorer, follow these steps:
    1. On the Tools menu, click Folder Options, and then click the View tab.
    2. Under Advanced settings, click to select the Show hidden files and folderscheck box, and then click OK.
  3. Grant appropriate access permissions for the drive:\Winnt\Installer folder for the following groups: Administrators: Full Control
    SYSTEM: Full ControlTo do this, follow these steps:
    1. Right-click the drive:\Winnt\Installer folder, and then click Properties.
    2. Click the Security tab.
    3. In the Name list, click the appropriate user group or user name that you want to assign permissions for. For example, click Administrators.
    4. Under Allow, click to select the check box for the appropriate permission that you want to set, and then click OK. For example, click to select the Full Controlcheck box, and then click OK.
  4. Restart the computer.
  5. Insert the microsoft office CD into the CD or DVD drive, and then run the microsoft office Setup program.
  6. After the microsoft office Setup program has completed running, reinstall your antivirus software program.
Nov 10, 2010 | Microsoft Office 2003 Basic Edition...
How to install openal32.dll??i try to extract to system32 but error access denied appear...can anyone help me??
You will have to login as administrator to make changes to system directories.So try doing it with an administrator account.If the error occurs even when you are logged in as administrator then
then follow these steps to turn off Simple File Sharing, and then take ownership of the folder:
  1. Turn off Simple File Sharing:
    1. Click Start, and then click My Computer.
    2. On the Tools menu, click Folder Options, and then click the View tab.
    3. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
  2. Right-click the folder that you want to take ownership of, and then click Properties.
  3. Click the Security tab, and then click OK on the Security message, if one appears.
  4. Click Advanced, and then click the Owner tab.
  5. In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
    If you want to take ownership of the contents of that folder, click to select the Replace owner on sub containers and objects check box.
  6. Click OK.
    You may receive the following error message, where Folder is the name of the folder that you want to take ownership of: You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
  7. Click Yes.
  8. Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Hope it helped.
Oct 28, 2010 | Computers & Internet
Error 1920, Service almservice failed to start. Verify that you have sufficiant priveleges to start system services?? I get the above error while installinf automation licence manager V3.0 can you help????
hi,
Make sure you 're installing the app as a Administrator, try the following
right button click the selected install program setup.exe etc ,
select run as administrator.
Regards
gewiz.co.uk
Nov 11, 2009 | Computers & Internet
I CANNOT INSTALL ADOBE READER 9.1 ERROR MESSAGE 1402 APPEARS
Do the following solutions first of all please remove all previous versions of Acrobat, and then reinstall.
1. Choose Start > Control Panel (Windows XP)
2. Double-click Add Or Remove Programs.
3. Select Adobe Acrobat [version] and click Remove.
4. When prompted, confirm that you want to remove Acrobat.
5. Repeat the above procedure for all installed versions of Acrobat.
6. Restart the computer, and then reinstall Acrobat.
Now, perform the steps below during Acrobat Reader installation. The Administrators group listed below is the default local administrative group for Windows XP.
  1. Write down the path to the key referred to in the error message and leave the installation running. For example: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler.
  2. Choose Start > Run, type regedit in the Open text field of the Run dialog box, and then click OK.
  3. Navigate to the parent of the key referenced in the error message. For example, for the key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler, open (double-click) HKEY_LOCAL_MACHINE >SOFTWARE > Classes > .pdf.
    Note: These steps may vary slightly depending on the path in the error message
  4. Right-click on the parent key and select Permissions (HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf).
  5. Verify that the Administrators and SYSTEM is present and that Full Control is selected under the Allow column.
  6. In the Permissions dialog box, click Advanced.
    cid:1f55f5d78f3846839533f8a85e395973@joanne
  7. Select the Administrators group (1) and "Replace owner on subcontainers and objects" (2). Note: Select the current administrator account if the Administrators group is unavailable.
    cid:3ce74f38956e4dfcae487444ce8f86c9@joanne
  8. Select both "Allow inheritable permissions from parent to propagate to this object" and "Reset permissions on all child objects and enable propagation of inheritable permissions," (1) and then click the Owner tab (2).
    cid:be8ff9254ad94f29bec91706f67dc76b@joanne
  9. Click OK (3) in the "Advanced Security Settings" dialog box. Windows will now reset the permissions for each child object to correspond with its parent.
  10. Minimize the Registry Editor and click Retry.
    • If the error reoccurs with the same key proceed to Solution 4.
    • If the error occurs with another registry key repeat Steps 1-10 using the new registry key.
    • If the error does not occur finish the installation following the on screen instructions and exit the Registry Editor.
Please let us know how it goes.
May 06, 2009 | Computers & Internet
Symantec client security
here u got:
Question/Issue:
When you install Symantec AntiVirus or Symantec Client Security, you see the error message "1920 Service Defwatch failed to start. Verify that you have sufficient privileges to start system services."
Solution:
This problem has more than one cause, so more than one solution is provided. To fix the problem, try each of the following solutions in the order that they appear.
Confirm that you have the correct rights and permissions
The most common cause of this problem is incorrect rights or permissions. Make sure that you have Local Administrator rights to the target computer. Confirm that no restrictions on the Local Administrator or Domain Administrator accounts exist.. Follow the directions in the document Troubleshooting Symantec AntiVirus Corporate Edition installations: Checking rights and permissions.
Confirm that the Defwatch service has the correct settings
This problem can happen when the Defwatch service account has incorrect settings. Make sure that the Defwatch service is set to log on as the Local System account. Confirm that the service is allowed to interact with the desktop.
To confirm the Defwatch service settings
  1. On the Windows taskbar, click Start > Run.
  2. In the Open box, type services.msc and then click OK.
  3. Do one of the following, depending on your program version:
    • For Symantec AntiVirus 10.x, right-click the Symantec AntiVirus Definition Watcher entry.
    • For Symantec AntiVirus 9.x and earlier, right-click the Defwatch entry.
  4. Click Properties.
  5. On the Log On tab, confirm that the Local System Account is selected and that "Allow service to interact with desktop" is checked.
  6. Click OK.
Look for a Program file at the root of the OS drive.
If McAfee antivirus 4.03 or 4.5 was installed on the computer, look for a file that is named "Program" at the root of the OS drive. If the file exists, delete it.
Delete leftover registry keys from a previous version of Symantec or Norton AntiVirus Corporate Edition
Leftover registry keys from a previous version of Symantec or Norton AntiVirus Corporate Edition can cause this problem. Delete the registry keys and then install Symantec AntiVirus again.
WARNING: In the next steps you will edit the Windows registry. Back up the registry before you make any changes to it, because incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the registry keys that are specified.
For instructions, see How to back up the Windows registry.
To delete the registry key
  2. In the Open box, type the following text:
    regedit
  3. Click OK.
  4. In the Windows Registry Editor, in the left pane, click My Computer.
  5. On the Edit menu, click Find.
  6. In the Find what box, type the following text:
    VirusProtect6
    Delete all keys and values that contain this string.
  7. Go to and delete the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\DLLUsage\VP6
  8. Exit the Windows Registry Editor.
If the problem persists, manually remove the previously-installed version of Symantec AntiVirus. To find directions for your product version, read Manual uninstallation documents for Symantec Client Security products
And please if it was helpfull for you rate this solution as SOLVED
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
Top DameWare Computers & Internet Experts
David Payne
David Payne
Are you a DameWare Computer and Internet Expert? Answer questions, earn points and help others
