Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My whirlpool frig stopped cooling. it sounds like he compressor will not stay running. you hear it kick on but goes off after about a minute
    President:
  • 2,468 Answers
Your ptc overload on the compressor is bad
Posted on Sep 13, 2010
Compressor is hot and I hear clicking in back every couple of minutes. I understand that this indicates that the compressor is in a locked up / no start condition. the overload cools enough to reset and...
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
Oct 11, 2013 | Refrigerators
Cat number ED25TEXHW00, side by side, Whirlpool Refrigerator. Neither fridg or freezer will cool. Lights turn on & condens fan runs. Compressor will not kick in. What to look for???
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
May 30, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Old 2nd frig stopped working, no cooling, no compressor running, only light in compartment. Any breakers or things to check?
Of course check breakers, then unplug unit from wall for several hours (let unit compressor cool) then plug back in. If after plugging it in you continue to hear a "clicking" sound on rear of unit either start device on compressor is bad or compressor its self is gone.
Oct 16, 2009 | Refrigerators
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
2006 kenmore frig - freezer and frig are both hot
if both sides are hot it sounds as if the compressor isnt running. pull the refig away from the wall and remove the cardboard cover the compressor is the black bowling ball loking thing that you see. fell to see if it is running should have vibration and making a humming sound. if its not running listen for 3-5 minutes to see if you are hearing an intermittent humming and clicking noise. this would indicate a bad start relay for the compressor. if the compressor is running then you mostlikely have a freon problem which will require a qualified technician to repair. good luck and thanks for using fixya Peyton..
Jan 27, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frig and feezer stopped working
It sounds like the overload and relay on the compressor.If the problem isn't that then you need a compressor.
Eeggman
Nov 07, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
