Question about Epson TM-J7100 InkJet Label Printer
I have a EPSON TM-J7100 with power led blinking and feed paper led red, how can i solve the problem?
2 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: I have a EPSON TM-J7100 with de power led blinking
Have you experience a paper jam prior to this problem? Open all access doors and look closely inside. Check for any tiny paper shreds that might be stuck in between the rollers or might be jamming the mechanism. Then turn off the printer and pull the power plug from the source; then power it back on.
Posted on Sep 13, 2010
Epson t60 two orange lights blinking
use this interactive guide to resolve the issue. They are considered red lites not orange. FYI
Epson Printer Error Lights INTERACTIVE Meaning of Red Blinking Leds
Dec 10, 2014 | Epson TM-T60 Printer
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
Hello I`m Daniel, I working with Epson Tm J7100, the most of the problems is do not pirnt. I change the ink allready clean the Head, but make al the move like printing but still dont works, no blinking...
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Mar 18, 2011 | Epson TM-J7100 InkJet Label Printer
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
RE: Epson TM-U200 printer with error (2 Flashes)
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
May 27, 2009 | Epson TM-U220 Matrix Printer
Espon TM-T88III Not Feeding or Printing
Does it have a manual insert for the paper?
If it does, try putting the paper in that.
If not, or if that doesn't work, I recommend trying to reinstall the printer and drivers.
If that also doesn't solve your problem, please post back.
Apr 15, 2009 | Epson TM-T88III (C420863)
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Epson TM-J7100 InkJet Label Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
