The water inlet valve has likely failed. First check the screen inside the water inlet valve for debris. If it is clean you will need to remove the top cover and check to see if you have power going to the valve. If you do replace the valve assembly. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/washerwaterinlet.html
