Question about Bosch Evolution 500 B20CS50SNS
What is the snowflake and water drop light on the display panel mean
What does the snowflake mean
Cold Rinse? The plates come out ready to use rather than being hot.
Aug 13, 2015 | LG Dishwashers
Snowflake symbol light is on
It might be showing that the rinse aid level is low. Top it up and see if the snow flake light turns off.
Apr 20, 2014 | Dishwashers
What is the red light that looks like a snowflake
The snowflake appears when the outside temperature drops to 40 degrees or below, it then changes to red when it is 32 degrees and below. It seems the manufacturer thinks this will assist you with your driving habits on frozen roadways.
Dec 20, 2010 | 2001 Mercury Cougar
Have portable a/c with dehumidifier. what is the drain in the middle of the unit for with a dial that shows a water drop and a snowflake, and what is the drain on the very bottom for?
The fully clockwise setting is the coldest (three snowflakes). The ... Water-cooling increases compressor capacity when the weather is very hot. Switch off ... Drain all water from the pump, sea strainer, hoses and water coil in the BD housing ...
Aug 21, 2009 | Fedders Dehumidifiers
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
I got a 2002 mercury cougar and there is a light that turns on an off once in a while it's the second 1 next to the wrench it looks like a snow flake what dos it mean
The yellow/orange snowflake means its between 42 and 33 degrees and the red snowflake means it's 32 degrees or below (fahrenheit).
Jan 28, 2009 | 2002 Mercury Cougar
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
Yellow warning light
Dunno where you reside but our indoor/outdoor digital thermometer shows a snowflake once the temp drops down to 0C/32F. It wouldn't surprise me to learn that a Jag would have a warning light for freezing temps.
Nov 16, 2008 | 2003 Jaguar S-Type
Black marks on display screen
That means that your LCD panel has been damaged. The only fix is to replace the screen (which is a hard and expensive job), if you can live with it then leave it alone..
Jun 27, 2008 | Samsung S1030 Digital Camera
Bosch Evolution  500 B20CS50SNS Logo
93 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
