Question about Okidata B2500 MFP Printer Laser
Hello, My Oki B2500 MFP says "Printer error fuser temp." with a continuous beep beep. I could find ntohing in the documentation. Thanks a lot for helping! Pierre Penot
5 Suggested Answers
SOURCE: I have an OKI B2520
This is a common error especially if you have power surges or outages, before calling in follow the following steps:
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  5. switch the first digit from a 0 to a 1
  6. press OK
  7. Press the Red Stop button
Now you need to clear the error
  1. press the down arrow
  2. Press #
  3. press the letter T ( on the keyboard of the printer)
It should reboot itself although it may not, if it doesn't then turn off the switch then back on. you should see some black bars flashing on teh screen. This clears the error and wil help determine if the fuser is actually broken. Before you print and start using it you have to set it back to operational mode by doing the following steps
  1. Press the Down Arrow
  2. Press *
  3. Press #
  4. select "SOS1"
  5. Change first digit from 1 back to 0
  6. press OK
  7. Press the red stop button
Those are the steps required to clear the fuser temp error from the okidata support desk
Posted on Dec 30, 2009
SOURCE: OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX
Posted on Feb 12, 2010
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
SOURCE: B2500 All-In-One Laser Printer: How to reset OKI B2500 toner chip?...
I am also having a proble with that....anyone?
Posted on May 25, 2011
  1. Press Down Arrow
  2. Press *
  3. press #
  4. select SOS1
  6. press OK
  2. Press #
  2. Press *
  3. Press #
  4. select "SOS1"
  6. press OK
* Please rate this solution and provide comment
Nov 12, 2010 | Okidata B2500 MFP Printer Laser
When we turn on the printer it starts beeping and it says error fuser temp.
Hi
Usually this means the fuser bulb has failed. This will take an experienced tech to replace the bulb. You might be able to get a fuser unit from www.katun.com
Aug 18, 2010 | OKI B2500 Black and White Copier
What is fuser temp error
The fuser is not heating up to fuse your toner to the paper. You may have had a bad paper jam that damaged something? Make sure there is no torn paper at fusing unit that has been missed.
Jun 08, 2010 | OKI B2500 Black and White Copier
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX THIS ERROR?
Sep 04, 2009 | OKI B2540 MFP Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
I have a OKI B2500 Series. When Print Says Printer Error FuserTem
If you have not fixed this by now, I have the fix.
Turn the printer on, hit the following keys on your printer:
down arrow, *, #, ok, 1, ok
After that, hit the down arrow until you see T>Printer and then hit ok.
Next turn off the printer, count to 5, and then turn back on.
Repeat the first step, but in place of the number one, insert the number 0.
These were the steps given to me by the oki customer service and it fixed my printer. If you have problems, the number is 800-654-3282.
Jun 07, 2009 | OKI B2500 Black and White Copier
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Yes
If error still exists_
Okidata B2500 MFP Printer Laser Logo
1,358 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
