Question about Garden
Husqvarna Pro Rider 15 problem: Having mown for half an hour the blades suddenly stopped turning upon lowering the front canopy. Engine is working and nothing looks broken. Looking at the belt and pulley system, I think the belt may have slipped. Should it travel around the outside of the spring loaded pulley wheel I can see towards the rear on the left underside? It is not laced around this at present. Hope you can help. Thank you. S Butler
  • 203 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
huffman49
  • 235 Answers
SOURCE: the main drive belt on my 46
best I can do is suggest going to your favorite search engine like google and type in the name of your mower and what it is you need and hit the enter button.. you will be surprised to find what your looking for...good luck
Posted on Apr 03, 2010
wireguy212
  • 1627 Answers
SOURCE: Have a John Deere tractor LA145 Yesterday while
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
Posted on May 08, 2010
SOURCE: Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Posted on Oct 28, 2010
rycgl
  • 1545 Answers
SOURCE: looking for the blade pulley
See pages 18, 19 and 21 of this manual. This model has 2 blades. I don't know your model number so could not download EXACT model manual. These diagrams and pics are very clear. Hope it helps.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__532436505.pdf
Posted on Sep 04, 2011
My husqvarna rider 15 v2will not turn over
Does the engine spin freely, is the battery dead?
Jul 09, 2016 | Husqvarna Motorcycles
Husqvarna Proflex 21 just stopped engaging the blades after bump over brick. Was working fine, on starting the next cut the engine goes well, lever works but no mower blades turn when lever lowered. T
Sounds like you have broken a shear pin in the drive pulley.
Shear pins are made to break if you hit something. Other wise it would cost a lot of money to repair the damage.
Jan 24, 2015 | Husqvarna Garden
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
What is the easiest way to change the blades on my yth23v48 rider
Blade removal instructions on page 15 of your manual state the best, conventional way (without removing the entire deck).
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_YTH23V48_532438710.pdf
Sep 13, 2011 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
While mowing my lawn the Husqvarna YTH1542xp with a twin Kawasaki engine suddenly stopped. Will not start again, had blown 20 amp fuse, replaced fuse and starter engages, but engine won't turn over....
Maybe it threw a rod or piston.. maybe the piston seized up. Can you get the blade to rotate at all? Use a stick to try that, not your shoe.
Dec 03, 2017 | Husqvarna Garden
Dec 23, 2009 | Garden
Husqvarna rider 155 won't start
I took a wire and jumpered all of the switches until I found the one that would let the mower start. The switch was still good, but vibration or whatever had moved the plug just enough to lose contact. Plugged it on more firmlly - problelm solved. Thanks.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
try checking the ignition switch for any damage and replace if necessary
Nov 25, 2008 | Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
