External hard drive can no longer save on. Existing files not affected. Computer says "Cannot copy. The directory or file cannot be created." Thanks
  • Anonymous Sep 27, 2008
    Same thing happens to me, this is the 2nd time and last time I thought I'd have to reformat me hard drive-usually that's the problem, is the fact you may not have formatted it correct;ly in the beginning-but I did something like safely removing it and then fixing folders..
    Genius:
  • 2,785 Answers
Scan for viruses
Posted on May 15, 2008
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
Proper or Best way to use my newly installed WD SATA external Hard Drive;
The files are placed on the drive by you. Unless someone setup a special application files will not automatically migrate to another drive. You would not generally want them to because they would never be where you left them and be much harder to find. Primarily you will want to be moving data files and not application files (unless you uninstall from the internal drive and reinstall to the external drive) You can open my computer and find both drives -- you can drag/drop folders (containing only data, mp3s, videos, etc) between drives. I always like to check these moves by doing a right mouse click selecting properties on each folder separately to assure that an equal number of folders and files were copied before deleting them off of the smaller drive.
I emphasize again moving programs in this fashion will cause them to break. If you have large and seldom used applications you can uninstall them then using the installation process and media provided by the manufacturer then reinstall them choosing the external drive as the destination..
I hope this helps.
Dec 09, 2007 | Western Digital Caviar SE WD800JD SATA...
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
How do use Verbatim to back up files
Which operating system ?
Determine how much space you need. The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files. You can do this in a couple of ways. Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties." This shows the approximate of your hard drive, how much space is actually taken, plus the space used by your operating system. If your hard drive is manageable (the space actually taken), back up the whole thing. Your second option is to create a file called "Backup" and copy all of your important files into it. Right-click on the folder once everything is copied over and choose "Properties" to find out the of the folder. This is how much space you will need to back up your important files only. Choose a backup method. Choose either an external hard drive, data disks (CDs, for example) or use an online backup service. Plug the flash drive or the External Hard drive into your computer's rectangular-shaped USB drive. Wait for Windows to recognize the system. Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration. Open the drive on your computer. Open the "My Computer" directory if using Windows XP or the "Computer" directory if using Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it. Transfer files to the flash drive. Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background. Open the folders or locations of the files which you want to save to the flash drive. Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window. Release the mouse button to let the files "drop." Close the windows and directory locations when finished. Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option. Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section. Click the "Save" button to save the file onto the flash drive. Close the windows and files when finished
Apr 03, 2013 | Verbatim Computers & Internet
Can't find back-up folder
You might have to create a folder you can do this by right clicking in the backup destination drive selecting new folder and name it lets say Back Up 2012 for the excercise.
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
Hope this helps.
Nov 16, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
How do I copy my complete music files from my computer windows 7 to Verbatim external hard drive with Nero software?
Hi!
Unless I'm misunderstanding, you shouldn't need to use Nero at all to copy your files.
If you use Windows Explorer and locate the directory with your music files, you should be able to just do a copy and paste to a directory on your external harddrive.
Mar 26, 2011 | Computers & Internet
I can't copy files from my Seagate External Hard Drive. The light is blinking but I can't open the hard drive from my computer. Earlier I was able to see the files but I can't copy them to a new hard...
Click "Safely Remove Hardware" in your tooltray (one of those little icons on the lower right
of your screen across from the START button - its a green arrow over a PC board). That'll
remove it from the system, then re-attach it (Windows Plug-n-Play will find it and re-mount
the drive).
Then, deep-scan your anti-virus software on your entire system - the possible cause of loss
of directory structure on your external HDD.
Then, run CHKDSK on your Seagate External Hard drive - to make the directory structure sane again.
How-to-do-this: START> Run > (type in) chkdsk
Then, download (free) "Recuva" software from http://www.piriform.com to recover anything lost in
making your external HDD's directory/file structure sane again.
Run Recuva in this mode:
Recuva > Options (button) > Actions (tab) > Scan for non-deleted files (for recovery from damaged or
reformatted disks)
Feb 13, 2011 | Computers & Internet
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I see only one out of meny dir's in seagate freeagent go ext disk
It sounds disk I/O is creating problem refershing the contents in hard drive.
You can try changing the drive letter on your hard drive, might help.
http://www.wikihow.com/Change-a-Drive-Letter-in-Windows-XP
Also, if any kind of corruption, you can try disk error checking scandisk
http://www.pctechguide.com/tutorials/HDDMaint_Chkdsk.htm
If nothing works, there is other way to see your data in cmd
go to Start->run->type "cmd" and hit enter
To go to your External drive's letter you should know the drive for eg, if your external drive letter is D Drive just type D: in cmd and hit enter. Now you will see he prompt D:\, type dir to list the directories and files in that directory/folder
If you are able to see your files in CMD, you can still back them up
Try following link for more information
http://dosprompt.info/
Jun 02, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
26 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
