SOURCE: very slow 2nd hand peg perego gaucho
I have the same issue. Called their customer service and they said it was a defect in the charging system. They are sending a upgrade kit for free, but when it's installed you can't charge the battery using the rear port anymore. No big deal. I'll report back when the fix is complete. 5-7 days until it gets here.
SOURCE: My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
I would contact the repair help at
http://www.shopjandl.com/
SOURCE: our son has the peg perego jd gator hpx 12 ride on
You can contact the peg perego service center at 1.801.655.0800. I have several of these toys and they always help me out when they are not working
hope this helps
SOURCE: i have a power wheel price fisher charger and i
hi, you will have change the adapter on the charger or the battery. do you have a peg charger thats not working? if so simply cut the connector off and splice it onto the power wheels charger. the chargers are simply a ac adapter so the only real difference is the connection points. get a cheap volt meter at harbor freight (under $5) and make sure you connect the + and - wires correctly, failure to do so will blow the fuse on the battery and maybe destroy the adapter. from your question im thinking you dont have the peg connector so can find those for sale on ebay or on http://www.modifiedpowerwheels.com . good luck!
