Question about HP Office Equipment & Supplies
Dont no how 2 change print cartridge - HP Office Equipment & Supplies
    Master:
    Sergeant:
  • 461 Answers
I'm not sure what HP printer you are using but below link might be helpful to you...
http://etech.maiila.com/?p=31
Hope this helps.. let me know if y ou need more details
Posted on May 15, 2008
I have an epson sx510w how to change ink cartridge
use the tool button to access the menu and let it know you want to change cartridges. IF you dont have the instructions then go here and download the basic operation guide
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX515W/Drivers-Support?defaultOSId=3&target=#
Jan 08, 2012 | Epson Office Equipment & Supplies
I dont know how to get into printer to change the ink cartridge hp deskjet 5850
Do this to change the cartride.
1 - Switch the printer on.
2 - Open the front cover by raising the black lid upwards.
3 - Wait a while and the print cradle will move to the right and will become idle and quiet.
4 - Press down on the cartridge to be replaced and slide it out.
5 - Remove the new cartridge from its packaging and remove the safety tape - dont touch the copper parts.
6 - Slide the new cartridge in, use a slight angle, and press until you hear a click.
7 - Close the lid.
8 The printer may print a test page
Apr 26, 2010 | HP Office Equipment & Supplies
My HP Photosmart D5069 does not print. All the cords are connected properly but when I go to print something nothing happens. When I look at the status it just says Error-Printing
If you have recently changed ink cartridges and used an off brand cart. you can get this response.
HP printers can be real picky about whose ink cartridge you use. They usually have a 3 cartridge memory. That is they remember the codes from the previous 2 cartridges , wanting the new one to be of the same (HP) type. There are various workarounds. Depending on the model there may be some differences. Usually they all involve simply removing and re installing a cartridge 3 times to brainwash the little memory chip. Sometimes it requires powering off and on between changes. It is a lot of frustrating repetition but HP wants to sell you INK.
A somewhat simpler cause of the print failure is often dirty contacts in the back of the cartridge or of its seat bracket. Easy clean is Q-tip and some Alcohol. Not to vigorous and dont leave any fuzz behind.
Good luck
Apeal
Aug 21, 2009 | Office Equipment & Supplies
The ink level indicator is more than 1/2 full yet the print quality is pale. I cleaned printer heads several times, alligned etc., but still pale print quality. I changed ink cartridges, printed about 40...
try to change the properties of the printer. Usually it has a configuration to increase the printing quality.
And also, look for the configuration for ink drying wait time. Change it to long.
If you dont have any problems with your cartridge. then i think you should need some adjustments from your configuration.
well, i hope this works.. :)
Thank you.
Aug 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Apr 27, 2009 | Office Equipment & Supplies
Changing cartridge on printer
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge.
7. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Jan 03, 2009 | Office Equipment & Supplies
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Will not print blue
Try this I triedi in my printer cartridge which was stuck for a while and only prints in red other colors dont. First you remove the cartridges get a clean dry tissue / towel paper and smudge the cartridge printing heads to the tissue it should give all the colors if not the ones that dont may have hardened. Get warm water (Clean) in a bowel and submerge the printing heads on the water not the entire cartridge to dissolve any deposits then try them again. Hope it works it worked on mine.
May 30, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
102 people viewed this question
Ben Johnson
