I have a westinghouse washing machine LT819S with error code 3f any segestion how to fix
  • Washing Mach... Master
  • 17,129 Answers
If water is not filling then it can be the failure of the inlet valve, if water fills but does not stop the error can be the water level sensor and if the motor does not work with voltage to the motor, it is failure of the motor.
However if there is no response at all then the control board is faulty.
Posted on Sep 13, 2010
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
Fault code 3F? Westinghouse smart drive LT819S
i found this answer in another place
The F3 is as follows,
F3= Motor Sensing Fault.
Either the motor is faulty, or the sensor attached to the middle of the motor is faulty.
You can check the windings on the motor for correct resistances at the wiring connections on the harness plug.
Pins 1/2 should be 32 OHMS,
Pins 2/3 should be 32 OHMS,
Pins 1/3 should be 42/44 OHMS,
Any other readings apart from that means the motor is stuffed.
To remove it, undo the motor wiring connecter, undo the 2 bolts (1 on either side) of the motor and lift the motor away from the base of the machine. Also, you may have to undo the motor sensor wiring connecter also*
If the readings check out, then you need to replace the motor sensor which is attached to the very middle of the motor, visible from underneath looking up at the motor.
Mar 09, 2015 | Westinghouse Washing Machines
Westinghouse LT819S washing machine
I dont think its lube, if its direct drivce, the main issue with them is it puts strain on the motor when using a large load or even smaller ones over time. Get the motor checked and be careful because electronics catch fire very easily when you hear abnormal sounds, they burn or break, thats what happens to all electronics in the end even if in good care.
Aug 30, 2013 | Washing Machines
I keep getting the error message top-au followed by weird sounds on a westinghouse sensor drive
I tried to research this error but came back with no results. I would contact Westinghouse and talk to their support team.
May 08, 2012 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
Getting a beeping signal with a code message PF
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jan 24, 2011 | Kenmore 46472 Front Load Washer
Westinghouse LT819S 1F error and beep.
hello there
This is a verry common issue with these ovens
Here is the meaning and a few things to determine what is at fault i have it listed below
this error code can actually show up as any 1 of these and they all mean the same thing
F0 -
F1 - F7 Stuck keypad
may mean relay is turned on.or has
failed
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 21, 2011 | Kitchen Ranges
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Washing Machines Logo
559 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
