Question about HP Pavilion s3020n (882780985063) PC Desktop
No power on self test - HP Pavilion s3020n (882780985063) PC Desktop
    Scholar:
  • 181 Answers
First to be check is your power supply. Used power supply or brand new ones, does not matter as long as it is working properly, with correct voltage and ampere rating. Check your power supply with a voltmeter. Please take note also the total watts you need.. If your power supply is running good, problems will go down the line, the Motherboard. Remove all devices (hard disk, cards, memory, etc) just the motherboard, just to see if the motherboard is working right. Your should be hearing a beep sound indicating that the board is alive. If yes, you may reinstall the rest of the devices you removed.
Posted on Sep 13, 2010
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
The printer cannot read from the computer, what do I need to do tried all cables
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
Oct 18, 2009 | Lexmark X1240 All-In-One InkJet Printer
My lexmark x1290 isn't printing tho i have new ink cartridges
Oct 02, 2009 | Lexmark X1270 All-In-One InkJet Printer
My X1240 will not scan copy or print even with the computer.The only thing it will do is that the power light will come on....
Oct 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Canon I9900 self test
You might be able to initiate the self test by powering it off first. Then, when you power it on, hold the power button down for 5 to 10 seconds continuously. In many cases, that will start the self test to run, But hold the button down for 5 to 10 seconds without letting it up at all, upon turning it on.
Jun 12, 2009 | Canon i9900 InkJet Photo Printer
Printer will not print out anything
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the gray button is pressed?
1. Turn the printer's "Power" off (metal button).
2. Press and hold the "Paper Feed" (gray) button.
3. While holding the "Paper Feed" button down turn the "Power" button on and hold both buttons until the power light comes on 5-7 seconds.
4. Release both "Power" and "Paper Feed" buttons.
5. The printer should feed a sheet of paper in and print a test page.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
However, please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
May 21, 2009 | Lexmark X75 All-In-One InkJet Printer
I have a lexmark all in one and was trying to make a copy
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the purple/silver button is pressed?
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Make sure the printer is off.
2. Press and hold the "Color Copy" button.
3. While holding the "Color Copy" button, press and release the "Power" button to turn the power on.
4. Wait for the "Power" light to flash off and on.
5. Release "Color Copy" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
May 14, 2009 | Lexmark X2500 All-In-One Printer
I see the printer when i hit print...paper won't feed...the printer will not pront
However, let us know the operating system that is installed on your computer.
Apr 16, 2009 | Office Equipment & Supplies
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
HP Pavilion s3020n (882780985063) PC Desktop Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
