Question about Samsung Televison & Video
40 inch samsung, little over two years old. trun on the tv with remote or manually the tv just ckicks about 3 seconds between clicks and takes a few minutes to come on .. seems to slowly take longer to come on each time
  • 85 Answers
Hi there.your set needs four new capacitors fitting on the power supply.they are grouped together,if you take the back off,you will see they have domed out on the top,and may be leaking brown fluid.if you are reasonably handy with a soldering iron,replacement is dead easy.caps are only a few pence each,take note of the polarity when changing.this is a VERY common problem.
regards,steve.
Posted on Sep 13, 2010
  • Rob Villeneuve Sep 16, 2010
    Do you know the specs of the capacitors that need to be replaced? It would be handy for me to buy the right ones before I open this up.
  • Steven Hill
    Steven Hill Sep 23, 2010
    hi rob,the specs and voltage are on the sides.just off the top of my head,think they are 1000 uf.
    rated at 10 or 16 volts.replace with 105 degree low esr types where poss.top brands to use are (my favourites) 1.dubilier,2 nichicon,3,elna.
    avoid all the cheapies where poss.they work,but you will be swapping them more often.....
    This is why samsung have the problem,and they know about it too.
    if you get stuck,will send you the parts you need .email me at tellyman139@hotmail.com.
    regards.steve
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
I have a samsung 42 inch plasama ty model spp4231 when i try trunin it on the red light comes on it blinks 5 times them truns offWhat's your problem?
Hi the blinking light is a code. The service manual for this TV will have a description of the code. do a google search for the service manual and download it.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
My samsung LE40R87BDX 40 inch LCD TV is 3 years old, is failing to start up the red light keeps clicking on and off will eventually turn on after 30 mins. Can this be repaired?
Yes,it the tv power supply board is dying and the causes.That the board,where the power a/c cord plug into it.U have all the tools and know basic soldering an electronic?Check the power supply board and replaced all the bad and dying capactors that are bulging or puffing up on it tops.This problems,will be solved.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 25, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
It takes around 3 minutes for the TV to trun on after we push the remote. At first it used to be few seconds then longer and longer. Now it takes around 3 minutes for it to click in.
This problems is the tv power supply board.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders and u know basic soldering and basic electronic?Check the power supply board for dying soon to be dead parts call capacitors.These dying soon to be dead capacitors are alway bulges or puffing up on it tops.After u replaced these dying soon to be dead capacitors,the tv well go back to powering up again like a few seconds.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
The TV ckicks and clicks and clicks instead of turning on for up to 5-10 minutes
The problem is with the PSU of your TV, may be a dry solder or probably weakened capacitors, you need to replace all those capacitors that are swollen/leaked, ensure the power cable is alright.
Nov 20, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
LN-S4041D 40 in. HDTV LCD Television: OUR SAMSUNG T.V IS A 40 INCH AND IT CLICKS, CLICKS...
Is there a clicking sound? Unplug the power cord for 20 seconds and see if this helps reset the circuitry. If the clicking continues, go to http://www.fixya.com/support/t722954-samsung_lns4051_dx_makes_clicking. If you can see defective caps on the power board and don't feel comfortable replacing, parts can be ordered at PartStore.com.
May 16, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
402 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
