Question about Intermec EasyCoder PC4 Label Printer
I connected the printer using a usb cable, downloaded the usb drivers and the printer drivers from the website. But the thing still fails to print. Cant even print a test page. Pliz help..
  • 1 more comment
  • Deepak Chavan
    Deepak Chavan May 11, 2010
    1.Is printer gets autodetected on Connecting via usb to pc?
    2. if answer is NO, check any other priter connecting to same cable.
  • kipdole Jul 02, 2016
    You need to go into device manager then look at the com port number Intermec created. Then when you us the driver wizard you need to choose that port for installation. Note there is a 2 step process to install the driver.
    Honeywell has bought Intermec and they have a new driver out that I think may be flawed. The intall wizard worked great and worked for about a month and then failed for 2 of our printers. The old driver is hard to install but works. Use the driver that comes with the printer.
    I think Honeywell wants people to buy new printers and this driver may have an intentional bug. After hearing what Volkswagon did regarding their emissions testing I no longer trust companies. Sorry because I may be wrong about this.
JUST PUT IN TO PORT COM3 AND GO.
Posted on May 12, 2010
    Intermec does not always choose com3 three. Look at the properties of port numbers in device manager. One of them will say Intermec, that is the port number.
  • 21 Answers
Is the printer set as your default printer?
Posted on Jul 30, 2009
    Scholar:
  • 45 Answers
Try the Seagull driver, at http://www.seagullscientific.com/aspx/thermal_95.aspx.
Scroll down to Intermec, downlaod and unzip.
Use the DriverWizard.exe to set up your printer with a new name (delete the original after you're sure this worked).
Posted on Sep 24, 2008
2 Suggested Answers
JongCur
  • 88 Answers
SOURCE: Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
Posted on Jun 21, 2008
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Label height is not managed correctly on the intermec easycoder PC4 that I got second hand... How to deal with this issue???
Go to printer properties and put in the custom label size. You will need to do this for each user of the computer.
Jun 28, 2011 | Intermec EasyCoder PC4 Label Printer
I need intallation guide of intermec easycoder pc4 & driver download link hlp me thanks
http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Apr 01, 2011 | Intermec EasyCoder PC4 Label Printer
My problem is i am connecting the intermec pc4 on the laptop windiows 7 and it does not have a pararell cabel in the laptop i am trying to make the mashine recognize the serial and usb port
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!
We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)
Intermec Install Notes: (from Intermec)
How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?
Answer
Tools Required:
1. EasyCoder PC4 (PC4B or PC4C) printer.
2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)
3. USB Cable.
4. Available USB port on your PC.
5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Note: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.
1. Download and unzip the USB drivers to a location on your PC.
2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.
3. Turn the printer On.
4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.
5. Click Browse and select the location where you unzipped the files in step 1 and click OK.
6. Click Next. The USB driver will now install.
7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.
8. Click Browse and select the location where you unzipped the files in step #1 and click OK.
9. Click Next. The USB Serial driver will now install.
10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.
The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.
(You may need to set the printer as the default printer)
Other things to know about these printers: ( not from Intermec )
1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.
2) You should use Intermec labels, if you otherwise the labels will probably not print properly
3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
4) Every user will need to set the default label size.
5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine.
6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
Feb 18, 2011 | Intermec EasyCoder PC4 Label Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
2,193 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
