Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Underneath the freezer side, way in the back there is a constant drip coming from the tubing there, it then fills the catch pan underneath which then leaks onto the floor why it this tube suddenly leaking the fridge is only just a over a year old.
Assuming you have the KitchenAid fridge depicted, it has cold water and ice-cube making facilities installed, have you had these plumbed in to the water supply?
Obvious thought is a leak on the pipeline or control valve-gear, which I think is located to the rear lower left of the unit (looking from the front.
Otherwise all ‘frost-free’ fridges have a drain pipe from the refrigerator compartment drain trough inside, to a plastic container clipped to the top of the compressor. Here the condensate from the fridge is evaporated off due to the running heat of the motor. Check that this pipe is plugged in where it should be and that it is clear of any debris, old food-stuff etc. Some fridges had a fold of foam ‘cloth’ somewhat like a ‘dishwashing wipe’ stood upright in the plastic container to better evaporate the fridge run-off.
If the fridge is only now making excess condensate look at the door seals and run your hand all around when closed to see if you can feel any cold air loss from a particular area. It is sometimes worth running a little silicone grease down the seal on the hinge side of the door, to ensure it slides easily and doesn’t get creased.
Posted on Sep 13, 2010
Water goes into the bottom of the refrigerator so much so that it leaks out onto the floor. The freezer and refrigerator seem to be working well, however.
This unit appears to drip defrost cycle water down the inside the back wall of the fresh food compartment to the fresh food compartment drain. There is a tube connected to that drain that is item 84 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=114825&diagram_id=28705718#d28705718
You need to make sure that the compartment drain and the tube to the drip pan is free of obstructions. It is not uncommon after a long period for the compartment drain to clog. Also underneath the unit were the tube terminates in the drip pan the very end of the tube can sit in some pretty foul muck and clog just from drying out with lint and gunk on the end of the tube between defrost cycles. I often poke spot / zip ties in them initially to clear obstructions because they are so dirty.
Please feel free to respond with any more commets at any time if cleaning the drain tube and catch basin do not resolve the issue.
Thanks for choosing FixYa,
Kelly
Aug 18, 2011 | Frigidaire FRT18S6AW Top Freezer...
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Best of Luck,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
There is water leaking in the freezer. I imagine it is the ice maker. There is an "ice puddle" on the bottom level and occasionally water seeps out onto the kitchen floor. Is this easy to fix for a...
my model is not exactly the same but check for this this anyway:
Take a flash light & check for ice in the back vent underneath the very bottom shelf in the freezer. If you see ice in there, completely defrost until the ice is gone & the plastic drip hole is unobstructed. The leak on mine was happening because that hole had frozen over & caused excess water to flow into the bottom of the freezer & out the bottom of the door instead of through that hole.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Every now and then I have water running in the
This is normal. It will go into a defrost mode every so many hours depending on the size of your unit.The water is the defrost draining down the drain tube to underneath your fridge. There is a drain pan underneath that catches the water. On some units you might hear the refrigerant converting from gas to liquid and hear a gurgling sound also.This is also normal.
www.appliancehelponline.com
Apr 19, 2010 | Amana ABB1927DE Bottom Freezer...
Whirlpool 106.52562100 Side by Side. Leaking
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 19, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Leaking refrigerator
  • if the drip pan is not cracked or overflowing then it could be that the drain tube that goes to the pan is clogged.
  •  a good thorough cleaning of the freezer should help.
  • also pour a little hot water in the back of the freezer (i take the refrigerator outside and blast it with a hose, but thats just me), this will hopefully melt any ice buildup that may be causing the problem.
  • the tube sometimes runs on the outside of the refrigerator along the back.
  •  either way the tube goes from the bottom of the freezer to the drip pan.
  •  let me know how if you need more help.
Jul 01, 2008 | GALAXY Microsystems 63702 Top Freezer...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
199 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
