Hi
Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle
calls for it. In these cycles, the dishwasher pauses after it has filled with
water, waiting for the water to reach the pre-set temperature. What happens
next depends, as follows: On some units, the pause is timed and the unit
continues after the allotted time. On others, the cycle can't continue until
the water reaches the higher temperature. If you have this type of dishwasher
and the water isn't being heated (say, because of a problem with the heating
element or thermostat), after the unit stops at the heating cycle, it never
continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please do accept the solution if
the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
