My avol 32in lcd tv has a flashing green power light and the screen doesnt come on
  • 208 Answers
SOURCE: lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Posted on Feb 05, 2008
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 105 Answers
SOURCE: Newer Jvc tv wont turn on
1. hold the [vol-] and [menu] button.
2. while holding those, press the [power] button and let go of the [power]button only
3. wait 5 seconds then let go of [vol-] and [menu]
4. wait for a while(approx 30secs).....do you get a picture
This works for the JVC models that end in "9" and end in "0"
Posted on May 27, 2009
freetek
  • 5568 Answers
SOURCE: doesnt power up light on tv just blinks green
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload and the power supply for the backlight may be at fault.
Posted on Apr 22, 2010
  • 6 Answers
SOURCE: i want some avol 19'
Here are some that may work, depending on the actual remote, 231, 232, 235, 256, 262, 275, 276, 279, 290, 298, 329, 332
Posted on Mar 09, 2011
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Reset dynex tv
You can reset the unit by unplugging, wait 30seconds to 1 minute.then try again.
If still doesn't come on, the lightning may have done some internal damage, such as to the power supply or Main PCB.
Jul 23, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
LG 32in LCD when powered on the screen shows nothing and when we look from top the LCD panel is flashing black and white lights inside . There is sound comming.. checked the motherboard it is proper p
Back-light inverter board problem. Contact any service technician, or authorized service center for LG. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Televison & Video
Problem With the Sharp TV LC-32SB23U 32in LCD TV Serial No# 810825838
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 25, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Where is lamp location in polaroid 32in hd tv
Your model is a LCD flat panel which doesnt have a lamp. Instead they have a series of flourescent tubes behind the Screen which light the screen. The backlights hardly ever fail its usually the Inverters which fail when you dont have any picture with that model. You can get the inverter board and free technical assistance from www.tvrepairworld.com
Aug 03, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
The remote and power button will turn off the tv but will not turn the tv on. the green sensor light will come on but the screen stays black. If I unplug the tv and slowly plug it back in, the tv will...
you can be having problem in your relay circuit.it is cause by one cap maybe a 10mf that is not filtering properly.check around in that area.for leaking caps or a open transistor.good luck.
Mar 04, 2011 | Soyo 32in 1366x768 1200:1 12MS DUAL TUNER...
Screen won't come on
When u try it as a tv no picture,but does it have sound?Than ur LCD inverter board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter boad for the replacement.It a long board in shape.
May 11, 2010 | Philips 17MD255V Combo
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
Televison & Video Logo
402 people viewed this question
Top Televison & Video Experts
