Question about Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator
The freezer is working fine but the fridge is not cooling. The motor is running constantly. I did accidently leave the fridge door ajar for a few hours
Check to see if the cold air supply from the freezer to the fridge section is blocked and that the fan is running. The fridge uses cold air from the freezer to cool and many times the intake is blocked by something in the freezer compartment.
Posted on Sep 13, 2010
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Freezer working fine the fridge is not
The motor running constantly means the fridge is not sealed properly so that it is losing cold to outside. Check if the door of the fridge seals properly.
Jul 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
The ice maker doesn't work, the fridge compartment is warm and the door seal is hot
sounds as if your compressor cooling motor is out.....check it in the back on the bottom.....remove the cardboard cover and see if the fan is running...if its not and it is real hot in the compartment the fan will most likely have to be replaced
Jul 28, 2008 | Whirlpool Refrigerators
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator Logo
226 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
