Question about Saeco Vienna De Luxe Espresso Machine
My machine coffee driper is really bad, it pours really slow, so how can i clean the the hose? the pipe in the front is clean it seems like the hose is pluged with somthing
  • 1,089 Answers
Hi
More than likley you grinder is set too fine. Open the big knob to the largest #. Make 3 coffees, (push the button again and it will stop the coffee when it starts to flow, and it will reset the machine). After the 3 coffee see if it will flow faster? If it does when it starts to grind the next time turn the big knob down to a # 2 higher than you had before. See if that doesn't help?
Posted on Sep 13, 2010
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
I have had this happen when I used non bunn filters . perhaps they non bunn are too small thereby letting the water run over the top My bunn takes 3 minutes when it's clean to brew 12 cups .
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
if the coffee is ground too fine, it'll take longer to brew through. either grind more coarse or call bunn for a flow restrictor (800) 352-BUNN (2866)
Not brewing coffee or rinsing
I don't know. Maybe you should just buy a new one? But if it's like SUPER expensive, I don't know. :L eh. I'm just a 12 year old girl.
Dec 16, 2013 | Jura Capresso IMPRESSA F60
Not pumping out water
Most likely cause is a blocked drain hose. With water in machine try removing the drain hose from where it joins the house drainage (connection to waste under sink or pipe that is specifically for WM.) Put this in a bowl and lower bowl to floor. If water runs out the drain hose is not blocked, if no water runs then the hose is blocked. If water runs then the pump is either broken or blocked - when it should be pumping if it makes a noise then it is not broken.
To unblock the hose or pump - drain the water from the machine (there should be a small pipe hidden behind a front cover at the bottom of the machine put this in a bowl (it will be very slow.) Once drained you should be able to access the pump (it is really an impeller) this should have a screw on front, undo this and remove you should now be able to clean the pump housing. You can also check whether the hose is blocked by blowing down it or pouring water down it. If it is blocked then squeezing the corrugated part of the hose will free some of the blockage. Keep doing this until water can be poured down it. If you live in a hard water area then it would be worth while doing a very hot wash on a regular basis to removed undissolved soap from the machine.
Good Luck
Jan 09, 2013 | Washing Machines
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Cuisinart Brew Grind l2 cup coffee maker will not work .
Hello Donna,
I just had a similar problem with mine. What I did with mine was unplug it, lay the machine on its back, and remove the four #10 torx screws from the bottom. You may need to go to the hardware store to get the torx driver. You will find two orange hoses there. Work on the left one. Slip the little pipe clamp down the hose. Try to carefully remove the hose from the pipe without splitting it. If it does split, cut the hose and stretch it when time comes to reconnect it. Just inside the pipe you will see a little black valve. Clean out the calcified debris that you find with a fine wire. I found a bit of coffee bean and calcium deposit inside mine. Try to clean the valve as best you can. When you get is cleaned, reattach the hose and slip the clamp back to the pipe. Replace the bottom panel. Also, there is a "filter column or stick or filter stick on the back left of the machine (upright) which contains a carbon filter. Mine was utterly filthy. Open the stick and remove the filter to discard. Replace it when you can. You can get a new one or two on Amazon reasonably. Check the stick cavity for stray coffee grounds and clean them out. When done reinsert the stick. When I finished with mine, I ran the 2 part water to 1 part vinegar solution through the system and then brewed some fresh water a couple times until clear. Mine brews coffee like new and it's really good! This really is a simple fix and you can do it. Just gather your courage together and do it. :o) ...I really hope this helps and let me know if you have any questions. Regards to you, Norman Zink
Jul 03, 2009 | Cuisinart DCC-1200 Coffee Maker
Clogging Frequently -- Very slow brew
Hello enrichyourli,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Jun 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee on the Countertop!
This is how my husband pours: he holds the lid open with the thumb lever and pours. It seems to work better if you pour slow. (I am always in too much of a hurry:)
Jan 30, 2007 | Mr. Coffee TFTX85 Coffee Maker
Saeco Vienna De Luxe Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
