Question about Epson Stylus Photo R220 InkJet Printer
My Epson R220 gets a general error, when I attempt to print to the back of a printable CD. The power light goes off and the paper feed and ink LED's flash rapidly. Power-off and power-on resets it.
    President:
  • 2,777 Answers
I see, and when you say power off and on you mean with the power button correct? Try unplugging it completely from the wall for a full reset, leave it out for a good 2 minutes, and replug. Does it print a document normally after this? It may be something with that particular CD label... does it print other documents fine?
Let me know and I can help more for sure
Tim
Posted on Sep 13, 2010
    President:
  • 2,923 Answers
Can you provide me the exact error message that your Epson R220 got?
Once you have the paper and ink LED flashing, it means it has something to do with the ink cartridge. However, I will wait for the exact error message that you've got, so that I could double-check.
Thank you!
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus R220 CD Print Smears after printing.
It has to be a bad batch or the wrong system.
Are you sure that the disks are labeled inkjet printable and not lightscribe?
Most printables are white in color and lightscribes are tannish.
Jun 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R220 won't print. Paper feeds through OK, print head moves as if printing but no ink comes out. Tried several sets of cartridges and this makes no difference. Cartridges are recognised fine and no...
Nothing at all? Problem with micropiezo (micro pump) at head. But you said, replaced print head. So it might just lost electricity to head (problem with board).
Jun 10, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
This seems like you have two separate errors.
For the loss of ink problem, see my previous posts about under head cleaning. This should get you going again, but if not, there is another known issue which causes these machines to stoip printing. This problem stems from a manufacturing "feature" which results in a broken pipe. To get a fix for this you should contact http://www.TheServiceManualShop.com and ask about there countermeasure for loss of ink in the Photo R series
The second error with the flashing lights depends on the sequence in which they flash. If the power light is off and the Ink and Paper lights flash half second on and half second off but alternating, then you have a maintenance request. This is easy to sort with yet another kit from The Service Manual Shop (R220 rescue kit)
If the sequence is Power light off but ink and paper flashing simultaneously then you have a fatal error. These are somewhat harder to attempt to fix and may require specialist knowledge and big parts that put the machine beyond economical repair.
Having said that, it can be worth taking the machine apart and removing the ASF assembly then reassembling as sometimes the feed mechanism ties itself in a knot and throws up a scary error.
Hope this helps a little
Oct 13, 2007 | Epson Stylus Photo R220 InkJet Printer
Both Ink & Paper lights flashing!
Hi JayBirde Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands! If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed. If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things: Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached. Check the lid for the ink cart cover is full closed.
Oct 28, 2006 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
128 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
