Question about Linksys SRW2024 24-Port Gigabit Ethernet Switch (SRW2024KIT)
We ahve 2 no of Cisco linksys 2024 Switches. when the switch is is heated when it is having load and it is automatically getting switched off
    Genius:
  • 1,552 Answers
Check that the fan inside the router is still working.
Check that the exhaust "grill" is not blocked (preventing the fan from blowing-out the hot air).
Posted on Feb 09, 2015
5 Suggested Answers
ucdpdiddy
SOURCE: LINKSYS SWITCH
No. You will create a bridge loop. The only way to do this is if you have a smart switch capable of aggregating multiple ports into a virtual trunk.
Posted on Nov 24, 2008
  • 83 Answers
SOURCE: Lucent Cajun not talking to cisco catalyst
Not sure what Cat switches you have, but the cajun switch must use the same trunking encapsulation.  Older catalyst switches use ISL trunking which only work with Cisco switches.  Make the port between the lucent and cisco dot1q encapsulation on the cisco trunk port.  Also turn on debugging on the cisco and see what messages are generated.
Posted on May 03, 2009
  • 4350 Answers
SOURCE: my network is slow while
It is difficult to have havy network traffic and not show anything. The stacking should not be a factor, it is the actual file movement that is causing this, and there may not be a way around it. One possibility is to limit the bandwidth of the file transfer, but that just makes IT take longer....
It is difficult to repair around factual reality.
Posted on Jan 23, 2011
  • 4 Answers
SOURCE: Hello,
On the linksys switch set the trunk port connecting to the cisco to 'general'. Match the native vlan on the linksys switch port with the cisco. The native vlan on the linksys will be set to 'untagged' with any other vlans that you want passing over the trunk set to 'tagged'.
You probably have a good grasp of how to do trunking on the cisco. The linksys does it, lets say, differently.
Posted on Mar 11, 2011
Advise: Cisco Switch for small business?
I think Cisco Catalyst 2960 & 2960S Series Switches with LAN Lite, Catalyst 2960 Series Switches with LAN Base, and Catalyst 2960-S Series Switches with LAN Base is best choice. You can get more information in http://www.3anetwork.com/blog/cisco-switches-for-small-business/
Aug 04, 2014 | Computers & Internet
When I Connect Two Cisco SRW 2024 Switch with Uplink Port ,Uplink Port get Disable
Most newer switches have auto detect MDI / MDI-X ports, but try a cross-over cable since this model is end of life.
Feb 26, 2013 | Linksys Cisco SRW2024 24-port webView...
Is NATing possible on ZyXel ES-2024 ?
The ES-2024 is strictly a switch so it doesn't have any NAT functions. It is just a Layer 2 switch so you will get basic MAC filtering functions and VLAN options.
Jan 25, 2011 | Zyxel ES-2024 (91010008002) 24x10/100 Mbps...
My network is slow while copying/transferring file over the LAN, we have Linksys Switch 224G4P and Linksys Switches 2024 which are stacked. Is this a problem
Jan 23, 2011 | Linksys SRW224G4P 24-Port Ethernet Switch
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
Need to locate PC's on our network, accurate to the switch port.
If its not to many computers , tone out the lines with a network toner
Jul 06, 2009 | Cisco Catalyst 3750G-24T SMI...
LINKSYS SWITCH
Nov 24, 2008 | Linksys -Cisco 16Port 10/100 RM Switch [...
Linking wrt54g with actiontec m1424wr
You need to check the ip address of your actiontec router, the default ip address of linksys router is 192.168.1.1, they should not be the same or else you will not able to connect the router to the internet.
To access the router web configuration
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3676&p_sid=fvzPHEYi&p_lva=3687#
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
Let me also give you the site on how to add the linksys router to another existing router.
The linksys has 4 LAN port and 1 "Internet" port on the back - we ONLY use the LAN ports NEVER the Internet port - because your existing router is connected to the Internet - your linksys is connected to the LAN
http://www.kriyayoga.com/love_blog/post.php/368
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys SRW2024 24-Port Gigabit Ethernet Switch (SRW2024KIT) Logo
192 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
