Back to:
Tags:
2006 Triumph Tr 8
1982 Triumph TR8 today
posted by lucasia on May 15, 2008
What is this car like today?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 15, 2008
Not Rated (0)
chiquititas
Rank:Wiz Wiz
Rating: 82%, 470 votes
As one should expect, the bloody thing is over 23 years old, an old car will have problems. Typical power steering leak. As well as just about every seal and gasket needed to be replaced for reliability due to it's age. Hey, you'd do the same if you had an American machine of the same vintage. As stated by others and on the excellent web site http://www.tr8.com this machine is a blast to drive. Of course if you let the car sit for 10 years you will have problems later. The engine is very quick provided one keeps up on the maintenance (oil changes, lube, etc.) religiously. These motors don't like dirty oil and will reward you with a damaged camshaft as well as gummed up internals. Expensive. Good thing about the parts are that a lot of the engine ancillaries are American and can be updated with better seals, alternators, aluminum rad, neoprene bushings, uprated brakes, uprated struts, etc.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 1982 Triumph TR8 today:
I don't want to Accept this solution
This Problem Also Relates To: 2006 Triumph Tr 7 2006 Triumph Tr 8
Can you Help with these Cars problems?
Pontiac Grand Prix
How do I reset the "change oil soon"...
Nissan Maxima
my car is running good and then all my horses got down and...
Mercury Marquis
all lights work but my headlights dont, I can pull back on...
Pontiac Firebird
changed battery and memory needs to be reset. Car stalls...
Infiniti G35
my 2004 infiniti g35x rad fan every now and then stay on...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
