Question about Tricity Bendix AW1000W Front Load Washer
The cylinder is rattling when it spins. I have leveled the machine with spirit level to no effect John Brennan
  • Tricity Bendix Master
  • 19,396 Answers
Hi John.
If the drum is whobbly and making noise, then you may have a bad drum bearing. Replacement is a major repair.
If the noise is rattling, ensure that instead of coming from drum the noise is not coming from a trapped object inside the tub. Foreign objects such as small coin end up in the coin trap, whigh is located in hose to drain pump.
Once you drain down the coin, this will end up being caught by the trap filter.The coin trap is accessed removing the panel at the lower front side of the machine. Be prepared to collect water in the hose with a container. Remember to disconnect power before performing any maintainance.
If instead the problem is the drum bearing, you will get the noise turning in a loud rumble or high pitched noise when spinning.
In that case the repair is done accessing and replacing the drum. Outer panel, belt and part of motor assembly must be disassembled in order to reach the bearing located at the back side of the tub.
See:
Bearing for this model.
Washing machine and washer dryer bearing replacement guidance notes
Posted on Sep 13, 2010
My machine is making a scapping noise when spinning
Take a spirit level ,keep it on the machine and adjust the level by rotating the adjustment bolts given in the bottom of the machine nearer to the rotating wheels
Dec 09, 2014 | Beko Washing Machines
Loud humming on spin cycle slow down lg washer
Hi Charlie,
We too have an LG - purchased purely because its "drum is directly driven by a motor" and NOT driven by rubber belts which are slower and can wear and break and are noisy - It is ABSOLUTELY CRUCIAL that ALL washing machines on EARTH are LEVEL or else ALL H*LL will break loose! The LG machine is SCREAMING to be LEVELED!
Use a spirit level sitting on top of the machine to check that your LG is NOT sloping is level if NOT then adjust the feet accordingly. Check your machine for level VERTICALLY and also level from FRONT TO BACK. This is a B*STARD of a job to do. If you can't be bothered with it or don't have cash to buy a spirit level then ask around for a local retired handy person who would be thrilled to do it for you in exchange for a few PINTS OF BEER. Also take care that your Washing Machine
DRUM is NOT overloaded or OUT-OF-BALANCE - evenly distribute YOUR WASHING in it. FINGERS CROSSED. ;)
Dec 30, 2013 | LG Washing Machines
My washing machine shakes during spin mode
The machine must be level or it will shake. There should be feet under the front which screw in and out. Get a spirit level and adjust the feet so it is sitting level front to rear and side to side.
Also make sure it isn't rocking slightly when it's not running - if so screw out one of the feet till it's steady. If you don't have a spirit (bubble) level compare how vertical the sides are to the wall/cupboards etc. However a level is best as even a little lean can make it shudder.
Or your putting too much washing in it!
Feb 07, 2013 | Whirlpool Washing Machines
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
Shakes when on spin
Hi, your washing machine need to be leveled, use a spirit level, to level your washer, used washer legs for adjustments, after leveling of washer, place both hands on machine, and try to rock side to side, front to back,there should be no play (movements) on washer, make sure machine is firmly position, good luck.
Aug 13, 2009 | Washing Machines
Vibrating only on final spin
no cement is perfectly level so you will need to level it with a spirit level
Jun 11, 2009 | Washing Machines
How can I stop my ge washer from moving all over the floor on spin cycle
Hello dcd123
Welcome
You asked how can I stop my Ge washer from moving all over the floor on spin cycle.
You need to level the washer by using a spirit level and tuning the legs until it is true and level.
let me know how it goes.I'm sure that you just need to level the machine and you're problem is solved.
thank you for using our service
Please remember to leave a rating!
Oct 05, 2008 | GE Washing Machines
Ge top load washing machine
in each of the four corners are adjustment feet. they're white nylon bolts. use a spirit level to level the front, then put the level from the front to the back on both sides and adjust the rear feet.
Aug 22, 2007 | GE WBSR3140DW Top Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
103 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
