Question about Sakar Cameras
Your Sakar Battery Pack BP-FH50 is being refused by my Sony Handycam HDR-SR5.It states that your battery is unsuitable for this camera, and switch's it off.Please can you help me.
Connect the the cable that came with the battery. It worked for me.
Posted on Aug 06, 2008
Why i have to set clock after changing battery everytime
you need to change your settings to auto date and time update
Nov 24, 2011 | Sony Handycam HDR-HC7 Mini DV Digital...
Dear Sir, Recently acquired SONY HDR-PJ30. Bought extra np-fv100 battery for it. Doesn't function on PJ30!! Surprising is that it works fine on the HDR-SR5 that I gave to my youngest daughter. She...
Sry Sir, But unfortunately your device does not seem to support the battery pack although Sony sells them as an upgrade for your unit. Click HERE to see the three most common Sony replacement batteries for that device. Looking closely, i believe you may have a unit the is not throwing you the correct amount of power. Apply a voltmeter in DC to the two battery terminals and you should get 8.4 volts. If your reading is any more than .4volts difference contact Sony as you battery has malfunctioned. If it tests good, still call them and let them know that your handheld is not accepting it......They are designed to be compatible and Sony is VERY GOOD at replacing or repairing devices that aren't performing to their standards.
GOOD LUCK AND PLEASE RATE THIS POST!!!!
May 09, 2011 | Sony NPFV100 Lithium Battery for camcorder...
I am unable to locate the serial number on Sony Handycam HDR-XR520V. It isn't on the bottom. Help!
Look behind the battery compartment on the rear of the camera. When you remove the battery that should reveal the serial number.
Feb 28, 2011 | Sony Handycam HDR-XR520 High Definition...
When I open the lcd screen, the camera (sony hdr sr5) is off. the display only flashes for a split second. 1 in 10 attempts the camera works fine, but every time I must unplug the battery. the same thing...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Dec 18, 2010 | Sony Handycam HDR-SR1 HD Camcorder
My Sony HDR-FX1E refuse to power on
These camera are not DIY repair candidates. I would suggest that you seek out an authorized Sony service center. Most of these are sent to 1 of 2 locations for repair for a fixed cost.
Dan
Aug 24, 2010 | Sony Handycam HDR-FX1E Camcorder
I cant turn on my camcorder but it wont turn oon at all ive tried everything
Is the power pack connected? make sure battery is charged (around 5 hrs) if nothing this means your camera has passed away, sad that as lots of that model failed like yours.
Jul 11, 2010 | Sony Handycam HDR-SR1 HD Camcorder
When I turn on the handycam dcr-dvd108 it gives me a blue screen that says cannot use this battery in the camcorder. It is a brand new battery that we bought because it gave me the same message with the...
This camera problem sounds as if the battery is not sitting in it's contacts quite right, check below to see if you have the right one, I think they are mostly grey to fit your model.
Battery Type: Li-ion
Voltage: 7.4V
Capacity: 1500mAh
Color: Dark Grey
Dimension: 44.95 x 31.72 x 43.37 mm
Product Type:Replacement Battery (Brand New)
Replace Part Numbers:
NP-FH30, NP-FH40, NP-FH50, NP-FH60, NP-FH70
May 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
How to charge a EFORCE FH50 Compatible Battery
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)3_27_2012_9_39_48_am.gif
Apr 05, 2009 | Sony Handycam HDR-CX12 Flash Media...
Cameras Logo
71 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
