Question about Ovens
My integrated Baumatic gas oven's gas grill cuts out after 30sesc of starting up fine. After cutting out i hear 2 'clicking' noises.
    Master:
  • 471 Answers
The clicking noise is probably the igniter trying to restart .It sounds like a bad regulator or possibly a thermo coupler .You should have it serviced by a technician.
Posted on Sep 13, 2010
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Aug 04, 2010 | Baumatic B187 Stainless Steel Electric...
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Ovens Logo
103 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
