Question about Sony Ericsson K800i Cellular Phone
Configuration problem - Sony Ericsson K800i Cellular Phone
I cant send or receive text messages on my o2 k800i phone please help
Posted on Sep 16, 2010
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
Is replacing the Body Control Module on a 2004 Nissan Titan as easy as removing the old one and plugging in the new one?
The answer to your question is no, The BMC controlled directly by the BMC are.
1. Power door lock system
2. Remote keyless entry system
3. Power window system
4. Sunroof
5. Interior room lamp
6. Warning chime
7. Turn signal and hazard warning lamps
Configuration EKS00777
DESCRIPTION
U1000
CONFIGURATION has two functions as follows:
? READ CONFIGURATION is the function to confirm vehicle configuration of current BCM.
? WRITE CONFIGURATION is the function to write vehicle configuration on BCM.
CAUTION:
? When replacing BCM, you must perform WRITE CONFIGURATION with CONSULT-II.
? Complete the procedure of WRITE CONFIGURATION in order.
? If you set incorrect WRITE CONFIGURATION, incidents will occur.
? Configuration is different for each vehicle model. Confirm configuration of each vehicle model.
READ CONFIGURATION PROCEDURE
CAUTION:
If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be
detected in self-diagnosis depending on control unit which carries out CAN communication.
This came right out of the 2004 titan manual don't think it's the answer you wanted to hear.
Mar 31, 2015 | 2004 Nissan Titan
How to clean up configuration Huawei switch ? I use the switch Huawei S9306 in my network. [Y/N]:y reboot Warning: All the configuration will be saved to the configuration file for the n ext startup:,...
Maybe you should ask the manufacturer, they will give you the details configuration. And if you want to learn more about the Huawei switch configuration, please visit:
c:\docume~1\admini~1\locals~1\temp\%w@gj$acof(tydyecokvdyb.pnghttp://huaweis5700.over-blog.com
Apr 03, 2014 | Computers & Internet
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Configuring an alvarion router
well your asking a lot out of this. you need the software that came with it it tells you how to run it and ect... if you lost it look it up online for the software.
Jun 04, 2009 | Alvarion BreezeNET AP-10 PRO.11
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
