Question about Bosch Axxis WTA 3500 Dryer
The dryer only works for a short time, then it beeps a few times, and the dryer stops. It doesn't matter if it's on the driest setting. A light is flashing, for the setting you have put it on (if it's extra dry, then that light will be flashing). I have to restart it many times to get the clothes dry. Please help! Is the machine broken, or can it be something easily reparable? Thank you!
  • Bosch Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
I have anElectrolux EDC47130W sensor dry 7kg condenser dryer. Its only a week old and worked great till yesterday. Whenever i select a program or time setting the start/pause button starts beeping and...
I think that there are errors on the program controller . As your set is new I would suggest that no tampering be done but the matter reported to the Electrolux dealer from where you had bought the machine for th privilege service under warranty.
Sometimes it might be better to register the service as the warranty gets void if tampered.
Mar 30, 2011 | Electrolux Kitchen Ranges
My gas dryer started beeping intermittantly while not in use. When I went to check on it, the lights for the towel setting were on (which was not even the last setting used). When I pushed the...
I say it depends what its going to cost to repair. I had a dryer that worked twenty years and when I replaced it they told me I would be lucky to get eight to ten years out of a new one. Its a throw away society now days.
Mar 03, 2017 | Whirlpool GGW9868K Gas Dryer
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Dryer turns off in 10 minutes.
To check the moisture sensors. Make sure the dyer is plugged in and all controls are set to off. Next to get into the diagnostic mode press more time, less time, more time, less time, all within 5 seconds. Now all indecator lights on the console are lit up with 88 in the " time remaining" display, if the test mode has been entered. Now this how to check the moisture sensors. Open the dryer door. You may hear a beep sound and the software revision number will be displayed on the console. If this happens there is a short in the moisture sensor system and the moisture sensors need to be checked and probably replaced. If this doesn`t happen,locate the moisture sensors on the face of the lintscreen housing and lay a wet cloth or towell across them. You should hear a beep and the software number will be diplayed on the console. If this happens then the moisture sensors have past the test and your problem is even deaper into the electronics and may reqiure a technician to trace this problem down.I hope this has helped you.
Nov 10, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore Elite HE3
replace the power control board
Jan 21, 2008 | Kenmore 82822 Electric Dryer
Dryers Logo
294 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
