Question about Philips QT4045 Beard Trimmer
I own a qt4045 with 4.3v adapter instead of 6v
My child was given this keyboard, but it is missing the DC 6V adapter/charger. It looks like we will have to purchase a generic 6V adapter but do I get the 6V 1A or 6V 2A? Thanks in advance!
The keyboard's input should give you the amperage requirement. If not there, get the 2 amp just to make sure it will work. The higher amperage of unit will not harm it if unit calls for 1 amp.
Jun 08, 2016 | Computers & Internet
Where can I get AEG Adaptor 6v-1a
Anu 6V 1Amp DC adapter can be used. It can be available at most of the electronic spare part selling shops.
Gopakumar Gopalan Google
Nov 14, 2015 | AEG Toys
Hiw many mA does the adapter for labtec lcs150 speakers need
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
No 6V power via power adapter to Sony ICF-SW7600GR
Could be a diode or a capacitor. Where are you located?
Feb 07, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
I got a Vital Fitness RB260 recumbent bike and it did not come with the AC adapter. I need to know the type, volts and amps or MaMPS or a part number so that I can order one. Thanks.
I have the same bike and my AC adapter is ripped in two. I have also been looking for a replacement cord. The adapter says model:GSD0060450006C
input: 110VAC 60Hz 0.1AMAX
OUTPUT:reg6V 450mA 2.7VA
Please let me know where I can order another one! Thanks!
Nov 21, 2009 | Cycling
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
I would like an adapter for my Bose personal CD player so I can use it without batteries. It requires a 6V 350mAh ac adapter. Will a universal adapter with various volt settings and up to 500mAh work with...
if the settings are too far off it can hurt the unit, if they are close, it should work (say 6v and300mah or 400mah), if you take it to a RadioShack (not sure where you are) or electronics place they should be able to get you what you need. Please give a fixya if this helps or helps solve
May 15, 2009 | Bose Pm-1 Portable CD Player
Looking for a power cord
Hi guys,
Had the same problem yesterday. Went to Radio Shack and picked up a universal power adapter (Model 273-1696). It can be set for 6V and will draw the required 2000mA. Box does not include the right size plug, but the salesman gave me one that fit for no extra charge. Cost 32.99. Everything is working fine now.
Jul 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Philips QT4045 Beard Trimmer Logo
127 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
