Question about Sharp AFR120FX Air Conditioner
SHARP AIRCON BRAND NEW - NO COOL AIR
HELLO. I JUST INSTALLED A BRAND NEW AC IN MY ROOM AND WHEN I TURNED THE COOL BUTTON ONLY FAN IS WORKING. NO COOL AIR IS COMING OUT. WHAT DO YOU THINK IS THE PROBLEM? THANKS!
    Scholar:
  • 57 Answers
The problems are to numerous to guess. a wire off, a bad control.
I would suggest you return the unit to where you bought it, and get a replacement or in some cases there is a warranty phone number on the paper work you can call. According to the manufacturer they may send a service tech. out to make any repairs. If it's under warranty let the manufacturer honer there warranty. you'll be glad you did.
Posted on May 16, 2008
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Sharp portable air conditioner
If the unit wont cool then its more cost effective to replace the unit. Mostly it'll cost as much or a little less than a new unit for repairs
Aug 05, 2013 | Heating & Cooling
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
My ac was serviced and 8.8 shows on the display and its not cooling, every button i pree either turns it off or on. how do i fix that?
does it work on heating ? when its on make sure you wait for a minute for the fan the start. when you say not cooling is it just blowing room temp air around or no fan nothing?
Nov 09, 2010 | Sharp Comfort Touch AF-R120EX Air...
My honda prelude 1992 s the air con doesnt always work! like sometimes ill press it in and the light will come on on the aircon button but mostly it doesnt! the aircon only sometimes comes out cool i think...
need to check the back side of the ac connector where the harness plugs in remove the heater control unit assy and u will see the ac button connector with it still pluged in start the car and turn the ac button on wiggle the ac connector if the light comes on and off it's a loose connection in the harness/connector at the ac button try to jamb a folded over zip tie about 4inches long in between the ac button connector and the plastic frame basicly just make sure that the connector staitionary not wiggling around I had the same problem on my 95 prelude vtec push the ac button sometimes comes on or hitting the dash just got old hope this helps
Sep 30, 2009 | 1992 Honda Prelude
Goodman fan running but no air coming out of vents and temp is now 85. Also, is there a restart button on the machine
you have to chaeck if the outdoor unit is running you the t-stat has to call for cooling in turning closing contacts between r and y the pulling in coil at condensor. your outdoor unit is not running
Aug 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Apr 19, 2008 | Heating & Cooling
Sharp AFR120FX Air Conditioner Logo
149 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
