Hi , i have a question that is hp laserjet 4350 error 57.04, changed the main fan already , but the error still on, why? thank you
SOURCE: hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Posted on Nov 16, 2006
ctf1800
  • 4402 Answers
SOURCE: 49 4C02 error
turn off the IPP protocol, and turn off Multicast IPV4
The 49.xxxx errors are indeed related to firmware and the formatter and can indicate faulty firmware or formatter... but are almost always triggered by some kind of communication that the machine doesn't know what to do with... thus generating an error.
Power fluctuations (not clean power), or random noise (RFI/static) transmitted on network or printer cables can also cause this problem. If your unit sits on a line of power that is shared with other devices (another printer/copier or a group of computers or a vending machine or cooler)... move it to a dedicated power outlet.
If it's caused by signals the machine is receiving, it can be tricky to correct.
Posted on Feb 19, 2008
SOURCE: hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Posted on May 28, 2008
xcanox
  • 32 Answers
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
I have problem of hp laserjet p4015printer 57.07error
This appears to be a fan disconnection or malfunction.
It will need to be serviced by an engineer who knows the internals and can open the printer without damage.
1 Verify that the connector J65 on the dc controller is firmly seated. 2 Listen for the fan to operate while the MFP is initializing. 3 If the fan does not operate during the initialization sequence, replace it. See Main fan (FN101) and reversing-unit fan (FN103)
HP RK2-0278-000CN Cooling Fan
MFG Part Number: RK2-0278-000CN Condition:Refurbished MFG:HP This HP RK2-0278-000CN is Genuine and works with the HP 4200, HP 4240, hp 4250, HP 4300, HP 4345, HP 4350, HP M4345, HP M4349 Printer series. Parts are thoroughly tested, inspected for damage & defects and guaranteed 100% fully functional.
Feb 06, 2016 | HP Office Equipment & Supplies
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Mar 20, 2008 | HP LaserJet 4350 Printer
867 people viewed this question
k24674
jasbo
jasbo
