Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
I have a single drawer f&p dishwasher drawer, and it does not empty after a cycle, leaving approx 15.. of water in the bottom. Any advice would be appreciated. Thanks. mark
  • Fisher and P... Master
  • 3,247 Answers
If you have a single drawer unit, then most likely cause is the drain is blocked at the kitchen sink end.
IF that is not an issue, then the filter plate and drain sump need to be cleaned.
Posted on Sep 20, 2010
Leaking clear water from behind the faceplate
Most likely the lid seal and/ or the detergent dispenser seal is leaky. Do not operate the dishwasher in this condition as the water can cause electrocution because the mains voltage comes up to the drawer front panel. Most likely it is the detergent dispenser seal.
see this diagram.
http://spares.bigwarehouse.com.au/images/files/18816_a21ebb5ac093d66472cef9bd1e8f3b12.pdf
Feb 16, 2014 | Fisher and Paykel DD24DCX6 Dishwasher
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have the two drawer dishwasher and skunky water is backing up in the drawer when I run the dishwasher. For example, if I run one drawer then really bad smelling water will stand in the bottom of the...
There is a possibility that the rotor motor which drains your water out has failed or that the propellor has worn out.
Open the drawer and remove the dish tray and cutlery basket. To remove tray, it is easier to lift the back of it up first then the front so that you clear the soap tray knob.
Then remove the filter mesh which is the disk on the bottom. To remove untwist the centre anti clock-wise half a turn. This releases it so that you can lift it out.
If you have water left on the bottom, empty out in a container with a sponge.
Then you will be able to see the top of the rotor motor in the centre.
Again half a twist to free it and then lift it out. Once you remove it look at the propellors to see if they have not chipped away. Most of the time the rotor stops working.
You can swap the rotors from the good drawer to test and see if it pumps the water out.
Normally when you start a new cycle, you will first hear the machine roof seal motors working for a couple of seconds, then the machine goes into an initial pump cycle for about 15 seconds. After this you will hear it stop and then start filling up with water. Once it has filled up with water, stop the machine and repeat a new cycle.
Pause the machine after the initial stage to see it it has pumped the water out.
If the problem is the rotor you can order a replacement and fit it yourself. Very easy to do.
Ash
Sep 19, 2011 | Fisher and Paykel Dishwashers
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I HAVE A TWIN DRAWER MACHINE ABOUT 5 YEARS OLD THE TOP DRAWER IS WASHING DISHES BUT LEAVING WATER IN THE BOTTOM OF THE DRAWER WHICH I AM NOW HAVING TO EMPTY MANUALLY HOW CAN I FIX THIS PROBLEM
Have you tried running the rinse cycle to check if the water drains out?
If you are not getting any fault codes, then it might be simply a matter of cleaning the base filter plate and the sump. The user manual will tell you how to do this.
If that does not help then post a comment along with the model number of your fisher and paykel double drawer unit and I will suggest further diagnostics.
Jan 29, 2010 | Fisher and Paykel Dishwashers
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The drawer will not drain down. there is no warning symbol after the cycle, but always water in the bottom. I have emptied the water and tried the cycle again but the same result. How do you drain this...
If you have already emptied the drawer and it continues to happen then it means you need to have a tech out to replace the "flap". The flap prevents water from re-entering the drawer unit, when water isn't able to empty it means the flap needs to be replaced which is a common problem with these models. It occurs when you are considered a "heavy" user as well as someone who rarely uses their unit (someone in a vacation rental).
Nov 02, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
73 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
