Question about Goodman Heating & Cooling
What is the range of Air Conditioning machines?
  • 144 Answers
Not many problems the main problem I see is people not cleaning regularly and it causes parts to go out faster I like goodman cause they have less parts on them which limits the amount of service calls and the parts are much less than other brands
Posted on Sep 13, 2010
No air conditioning on 2004 range rover
Please ask an actual question, including SYMPTOMS of the failure, and any TROUBLESHOOTING you have already conducted.
If the best you can do is say "it doesn't work," you should probably not attempt to fix it yourself.
Jul 29, 2014 | 2004 Land Rover Range Rover
98 Grand Cherokee air conditioner won't blow cold air after recharge
It sounds like your blend door isn’t operating correctly . The blend door simply is a flap that is designed to close off heater core when it’s calling for A/C , and opposite for heat . Check to see if it’s operating
Jan 17, 2018 | Cars & Trucks
Air conditioning switch on dash doesn't seem to work. How can I test it?
Remove the wire plug to the AC switch and then use DVM (Digital Volt meter) set to resistance at say 200 ohm range and use the meter probes across the two exposed terminals of AC switch (depressed position) to see if you read low resistance. If so it shows switch is working.
Mar 25, 2012 | 1989 Toyota Camry
I have one wastinghouse air conditioning, it does not work due to a fualt appar with E1 code. please support
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jun 16, 2011 | Office Equipment & Supplies
WHAT ARE THE USES OF AIR CONDITIONER?
Air conditioning can be used to raise or lower the temperature of an area or room, or to remove excess moisture from the surrounding air, commonly used in damp or badly ventilated rooms.
Mar 25, 2011 | Kitchen Ranges
Where do you add air conditioning fluid
u cannot add air conditioning fluid it has to be put on an air con machine to be topped bup the same as a fridge
Apr 02, 2010 | 2006 Chevrolet Cobalt
1999 Dodge Caravan Air Conditioning flucuating
Sounds like system is low on refrigerant and needs to be checked for leaks - could be anywhere on one of these.
Jun 26, 2009 | 1999 Dodge Caravan
Our air conditioning was working during the day. when one family member turned the air up from 72 to 75 she saw the screen process what she wanted and walked away. when another family member went to turn...
open the thermostat and look for batteries, 3 AA
http://www.heater-home.com/photos/2129-5b.jpg
http://www.heater-home.com/manuals/th8321u1006manual.pdf
Jun 13, 2008 | Honeywell Heating & Cooling
Blower for air conditioning fan
some cars ARE DISING LIKE THAT TO DRY THE MOISTURE IN THE A/C SYSTEM CHECK AFTER 15 MINUTES IF STILL RUNING THEN THERE IS A PROBLEM
Jun 01, 2008 | 2004 Land Rover Range Rover
Heating & Cooling Logo
20 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
