Question about Crunch BlackMaxx BLX2000D Car Audio Amplifier
Need help (autotek mx1300)
The amp power's up fine, green led is on an ncan only here it if i turn my deck up to max.And it sound's like a really small set of head phones and cut's out all fizzy.It cost a lot of money so i would really like to fix it.If you can help please ot red very very low sound i and thank you so much
The solution to your problem is to burn your car
Posted on Aug 06, 2008
    Genius:
  • 1,066 Answers
Find the input gain controls, theyre usually recessed into little holes, so you have to stick a small regular screwdriver into each of the holes to turn up both the left and right gain controls.
Posted on May 17, 2008
Amp light is green getting a base like heart beat nothing else fuses are good
The only thing I'm wondering is if you shorted out the RCAs somehow. Try switching the RCA's to another output on the back of the deck, if you have more than one set.
If that's not it...you will have to add pieces of the system one by one, starting at the deck, to see if you can troubleshoot the problem. Very Odd.
Good Luck
Dec 07, 2013 | Autotek Car Audio & Video
Autotek XS-900.4 stuck in protect mode
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Jun 06, 2010 | Autotek XS-900.4 Car Audio Amplifier
My Dual amp wont put out power when deck is in aux or ipod modes.
my pioneer deck does the same thing its just that when in aux mode, it will not play loud enough, i have to turn it up all the way just to hear a little sound, and i really dont know y, but when in those mods, it usually doesnt put out sound on ur subwoofer or amp rca wired on back of ur deck, and usually they do, but the power is not large enough for ur amp to pick the frequency up from ur rca wire connections. that also has happened to me before, i just usually ignore it, and just burn an mp3 cd w like hundred songs, so i dont need a ipod or mp3 player for aux.
hope i was help :)
Aug 14, 2009 | Alpine Car Audio & Video
Jh202 amp works for a few minutes stops for a few minutes any ideas
Sounds like the amp is going into Protection Mode. Does yours have green LED light then RED LED on it? The green is power and the red is Protection. You will need to either change the OHMS wiring or Put A Fan on it to Keep it Cool Inside.
May 11, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Autotek Bass Thrust 44 Wiring
thin blue wire is the remote wire and goes to the deck remote line
large diam wire goes to battery
large diam "black" goes to ground
rca ... wires with the metal ends plug into the white and red holes
you have two sets of speaker wire comming off the amp also
hope this helps
Dec 11, 2008 | Car Audio & Video
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
Autotek 7100 BTS series
99% of pots are off the shelf items.
See a tech with a parts catalog and a soldering iron.
Labor will far out price, the part.
Experience ain't cheap.
Regards, Sumthin
Jun 10, 2008 | Autotek MX3000.1 Car Audio Amplifier
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amplifer
recheck your ground make sure it has a good connection most of the time this is what it is
Feb 11, 2008 | Autotek SS290.2 Car Audio Amplifier
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
Crunch BlackMaxx BLX2000D Car Audio Amplifier Logo
95 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tygh Duval
Tygh Duval
Walter Dominguez
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
