Question about Hotpoint Washing Machines
When you put my hotpoint wt640 on to do a wash the water leaks out of the bottom of the machine
catriver
  • 878 Answers
SOURCE: Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Posted on Oct 09, 2006
jtate9
  • 68 Answers
SOURCE: Maytag MAV2755AWW Washing Machine is leaking water
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
  • 311 Answers
SOURCE: washing machine is leaking from bottom
Take front off and see where leak is coming from. Most common is either a split hose or bad tub seal. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
futureloginn
  • 734 Answers
SOURCE: My front loader is leaking water from the bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
Hotpoint ultima wt640 am getting a flash code f-05 clothes still wet appears not to spin
Hi Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps... Daniel
Mar 26, 2011 | Hotpoint Washing Machines
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
Feb 21, 2011 | Hotpoint Washing Machines
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
Hotpoint WT640 - it's flashing f-05. I emptied the machine and put on another wash and it says the same thing halfway through the cycle?
F-05 normally relates to the pressure switch,which normally points to a blockage.Does the machine empty slowly if so I would check the drain pipe first and if that is ok then you need to look down at the drain pump which may have a blockage in the filter which is inside the sump pipe,this is the main hose from the base of the drum and goes to the pump.
Hope this helps.
Aug 09, 2010 | Hotpoint Washing Machines
Cant wash it only spins hotpoint wt640 g
it seems as though the coupler under the agitator is stripped
May 07, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
