Question about Nokia E52 Smartphone
How to block the call from a particular mobile number on my Nokia E52 phone
  • 18 Answers
SOURCE: Incoming call blocking
This feature is not available on ur phone, get a nokia phone or other models of motorola that supports it. Alternatively, assign a silent ringtone to the number(s) and simply ignore it... lol.
Posted on May 04, 2009
asber
  • 291 Answers
SOURCE: SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Posted on Mar 03, 2010
Testimonial: "Very much relieved ... thank you"
  • 180 Answers
SOURCE: can i block a incoming call 4m a particular number
Download iMobileTool Incoming Calls Blocker 1.51 from the below link and block the number you want with this software
http://www.topshareware.com/free-call-blocker-nokia-5130/downloads/1.htm
Posted on May 30, 2010
fullbar_28
  • 624 Answers
SOURCE: my new nokia e52 phone is in lock mode right now.
try this one... hold the following buttons * (star key),3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons...if not works try this *#7370# then enter locked code..the default code is 12345..thanks ,i hope it will help
Posted on Jun 12, 2010
  • 252 Answers
SOURCE: hi i want to block
Greetings,
In order to block calls from a particular number you need to contact your service provider. You can dial 611 usually. They can put a block on that number for you, just let them know if you are getting harrassing calls, etc.
Thank you.
Posted on Apr 13, 2011
I am unable to receive call on my E52, from the numbers which are not saved in my phone.
The phone you are using is a good one, released in 2009. Its weak point is the camera. Please check and fiddle around your phone call settings. You can set it according to your preference. You can block all calls, receive calls only from contacts in your list or block some specific numbers.
Dec 01, 2011 | Nokia E52 Smartphone
I forgot my phone password so can i renew again?
- To unlock you Nokia E52 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 30, 2011 | Nokia E52 Smartphone
I want unlock my nokia e52 blocked by o2 pls send me advise
There are various ways to unlock a mobile device but the best way is to get it connected to a computer with an unlock software. This way the mobile device gets all functions unlocked as compared to other methods which would leave some functions of the device unfunctional. get a phone tech to help you do this as this way you can get the entire unit working.
Hope this solution has been helpful?
Jun 20, 2011 | Nokia E52 Smartphone
My phone is nokia e52 its turn off and i cant turn it on again please any one can help me
your mobile software is damaged you need to flash repairing your mobile at any n mobile repairing shop or nokia mobile service center. please don't forget to rating my solution.
Feb 01, 2011 | Nokia E52 Smartphone
Hi, please can you help me to unlock my Handy Nokia E 52 ? Thank you
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Jan 11, 2011 | Nokia E52 Smartphone
NOKIA E 52 INSERT SIM PROBLEM help
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.superunlockcodes.com/nokia-e52/rs12wp9/
Oct 31, 2010 | Nokia E52 Smartphone
I need a network unlocking code for my nokia e52-1 currently locked to o2 ireland... if possible need it asap
You can Try Unlock code for the Nokia E52 Locked to that Particular Network,You can try Unlock code at
http://www.prounlocking.com/nokia-e52/rs8wp9/
Oct 25, 2010 | Nokia E52 Smartphone
Who know the call barring password for nokia E52 plz help !! :):) thnx
I am having a problem in incoming calls, there is red cross(inside red circle) appeared on my main screen of my mobile E52. The incoming calls appeared in received call but i cann't receive my incoming calls. If you have the solution please let me know
Apr 06, 2010 | Nokia E52 Smartphone
Nokia E52 Smartphone Logo
1,071 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
