Question about BenQ FP72V 17 inch LCD Monitor
The screen went blank. I sent it to the authorized Service Center in Nehru Place, New Delhi. They returned it saying that a part has to come from Pune, India. It is 3 months now and they keep saying that the part has not come. Is there an alternatrive service cienter? he monitor is important to me and is beong warranty period. Can you help? Are you in India?. The monotor has to be repaired only in New Delhi. It went black within a year but now there is o warranty. Please don't tell me that I should buy a new one. Thanks..
SOURCE: BENQ FP731s Monitor Problem white blank screen
BenQ brand new high-voltage wire circle
BenQ LCD Controls circle / BenQ LCD accessories more high success rate, and easy maintenance, fault lower again!
Name : LCD Controls circle
Model : specifications : 1J.26048.011
BenQ LCD accessories four small mouth lights of the high-pressure reverse pressure plate used for high temperature must Taiwan curbs are enameled wire system. With a small noise, power, brightness control in high-efficiency low-loss. Rapid cooling loop can be designed according to customer-specific products.
2 features the use of high-precision inverter line Rao, insulation and can be a long time. 3 to 1. Electricity use light line measurement of high-frequency currents. 2. Backlight voltage output of a sinusoidal waveform. 3. The backlight brightness and the same as the original high-pressure plate. 4. 1-2 4.1 filament output AC exchange through the export of Maintenance and Spec - CN5 link to the. 5 and storage temperature and Temperature temperature ranges : -5 -- 50 ℃ work humidity range : 10% -- 95% RH the backlight should be within the scope of the above, the following conditions can store 40,000 hours. Operating temperature : -10 -- 80 ℃ work Humidity : 20% -- 95 % RH
BenQ LCD maintenance information
1 : BenQ LCD can switch planes normal (no signal light yellow, green signal), Looking carefully at the screen whether there are changes, they generally do not carefully read the screen can not see a change, oh, look at carefully Matata. Change or switch to a normal plane, the main board intact, such a high-pressure situation on board is no work, no lights lit backlight.
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good Off Power Plate,
3 : Measurement C5707, FQU11P06 (Some of the machines are used FU9024), whether the damage (breakdown) If the damage (breakdown), he seemed to see the appearance .22/160V capacitance whether deformation, If deformation replace, if not capacitance deformation on regardless.
4 : damage to the replacement of the device, if the fear of electricity burned again, you can Controls circle together too, In order to save costs if you should not start for high-voltage wire circle -- testing, If the damage C5707 meeting on the need to replace the high-voltage wire coils (most of the damage to the C5707 is Controls 72.9% Circle aroused),
5 : measurement of high voltage power supply board whether short circuit, without short-circuiting I would be grateful if insurance (PF801) new ones (General C5707 damage, insurance will certainly damage), If you do not have insurance you connect with fine copper wire, this 3-A insurance. Please stop the PF801 power-measurement, measurement inaccurate.
Understand how maintenance of electronic maintenance steps friends
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good power to remove board.
3 : replacement C5707 4 (Q809, Q808, loops, Q815) four high-voltage wire coils (T001, T002, T003, T004). 2 FQU11P06 or FU9024 (Qingdao, Q805). PF801 Insurance (insurance for the three A).
Posted on Dec 27, 2007
viziks
  • 220 Answers
SOURCE: Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Posted on Feb 16, 2008
Mark_Webber
  • 472 Answers
SOURCE: monitor
Look up the BenQ website. http://www.benq.com/support/
These monitors have a 3 year warranty in most cases.
Failing that cantact BenQ directly with the phone numbers on that same site.
Posted on Apr 09, 2008
bammbammfran
  • 159 Answers
SOURCE: Screen blacking in and out
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
SOURCE: Please help me fix this benq monitor
There are many posts that have solved this. Check em out
Posted on Oct 23, 2008
Please provide transcend service center address in Delhi
ACCEL FRONTLINE SERVICES LTD
203 ,Ashok Bhawan
93 Nehru Place
New Delhi- 110 019
Sandeep/Basant
30613072/737
No direct transcend service, Accel takes care of Transcend products too.
Dec 17, 2010 | Computers & Internet
Where is kingston pen drive service center in noida
Kingston Technology Authorized Service Center
Bharat Infotech
612, 6th Floor
Eros Appartments,
56, Nehru Place
New Delhi-110019
Contact Details :
011-65655693
011-9211840808
Dec 02, 2010 | Pen Drive (122077001) Wrist Watch
Hi, I ahve bought an Acer 8930-6442 from US in last summer.Last month there was water spillage on the laptop and it does not power up.I have contacted every service centre (bangalore and Delhi) but they...
Hi There!
It is better to get it repaired at authorized service center by giving some extra money as they have the right part rather than giving it to nehru place. They will replace the motherboard with some cheaper one ad charge you like hell. Try to convince the service centre fellow, give him some advance and try to get it done there only.
Cheers!
Sep 05, 2010 | Acer Computers & Internet
Please provide a asrock service center address in delhi
There seems no specific Asrock Service Center, but I know that Abacus Peripherals deals the Asrock and they do the servicing as well. You can contact them using this form.. Abacus peripherals india
Their Address/Contact Details in Delhi is;
Contact Person: Mr. Sourav
Mr. Soumitra Saha
Abacus Peripherals Pvt Ltd,
204, Sky Lark Building,
60, Nehru Place,
New Delhi-110019.
(T) (011) 32973154
(M) 09999911508 Mr. Sourav
(M) 09313899686 Mr. Soumitra Saha
Email:- delhi@abacusperipherals.com,
zionteam@zionram.com
They'll let you know the address of their service centers and they also do door pickup.
Good luck.
Thanks for using FixYa.
Aug 13, 2010 | Computers & Internet
Pen drive problem
Hi Mohit, If your pen drive is useless, you can contact
Bharat Infotech
208, Kaushal Bazar, 2nd Floor, 32-33, Nehru Place,
Near Ansal Tower
New Delhi-110019
011-65655693, 9310266387
Jun 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Mobile problem need service centre in east and south delhi
Below mentioned is contact no. and address for samsung service center in delhi. I hope this will help you.
Contact Samsung :
30308282&1800 110011(Toll Free)
Samsung India Pvt. Ltd.
IFCI Tower
61,Nehru place, New Delhi-19
+91 11 41511234
May 19, 2010 | Samsung SGH-E251 Mobile Phone - Black
My mother board DG41RQ is not detecting any hard disk drive
Here are two locations in delhi;
Upper Ground Fl, Block E
Int'l Trade Tower, Nehru Place
New Delhi
Delhi 110 019
India
21 Nehru Place, Suite 311
Paharpur Business Centre
New Delhi
Delhi 110 019
India
Jan 27, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
Please give to me address service center in delhi
Here are two offices that you can contact to find a service centre:
New Delhi
Delhi 110 019
India
And:
New Delhi
Delhi 110 019
India
Kind regards!!!
Jan 06, 2010 | Intel Motherboard
I have a intel moterboard which hangs. this is in warranty period i want to clame the warranty. but i am not able to do that i want to know the technical support center in delhi where i change the...
iconae.png Computer Repair Center - maps.google.com
118, Bajaj House, 97, Nehru Place, New Delhi, Delhi - +91 9968027897
More information »
iconbe.png Computer Service Center - maps.google.com
432/2, Veer Savarkar Block, Shakarpur, New Delhi, Delhi - +91 9891770397
More information »
iconc.png LAPTOPS -SILICON GLOBAL SERVICES - www.siliconglobal.co.in
C-2 nioda phase 2, noida, Noida, Uttar Pradesh - +91 11 4104 8019
Aug 29, 2009 | Computers & Internet
Service centre for intel motherboards
New Delhi
Delhi 110 019
India
New Delhi
Delhi 110 019
India
Also these telephone numbers:
BSNL customers
1 901 425 2105
Other customers
91 802 854 2105
Telephone hours:
10:00 to 19:00
(India time)
Monday-Friday
http://www.intel.com/cd/channel/reseller/apac/eng/support/32606.htm
Thanks for using Fixya!
Aug 24, 2009 | Intel Motherboard
BenQ FP72V  17 inch LCD Monitor Logo
46 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
