Alpine CDA-7897 CD Player
Problem for Alpine CDA-7897 CD Player
Faceplate problems
By longbeachbbo on May 15, 2008
After I take a cd out. The faceplate no longer will slide back into place. It seems as if the left side of the face can not slide back in. does the left joint need to be lubed or is it a malfunction
Solution #1
posted on Apr 04, 2009
Not Rated)
mddumas
Rank: Apprentice
Rating: 0%, 0 votes
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Alpine CDA-7897 CD Player
Questions and Unsolved Problems for Alpine CDA-7897 CD Player
Do you recommend Alpine CDA-7897 CD Player?
Answer
Answer
witch colour wire to cut on plug to stop speedo to fit a switch 98 mazda cappella 20,lt diesel
Answer
I have a Monsoon stereo system in my 2002 VW Jetta. today I put in a CD and got CDP Error 3. I do... (More)
Answer
I have a alpine cda-7998 headunit and the main display wont come on. What should I look for? There... (More)
Answer
I have a 1998 Corvette with a Alpine CDA-7897 stereo with external amps. There is a back feed noise... (More)
Describe your In Dash Receivers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in Windham, ME
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
