Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
Plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Posted on Oct 25, 2010
3 stove top burners will light with electric ignition and 4th ok with assistance
Sounds like the sparker is in trouble. Get the oven details and ask your appliance dealer or go online to an appliance spares site. Before you spend any money, have a second opinion from an experienced person. You may have to remove the oven top to expose the igniters. Find a handbook, this level of checks is usually in the owners manual.
Apr 17, 2015 | Hotpoint Kitchen Ranges
Reset change oil light
Driver Information Center (DIC) Equipped
Step 1 of 5
Place the key in the ignition and then turn it to the On/ACC position with the engine off.
Step 2 of 5
Press the "mode" button on the DIC until "Oil Life Left/Hold Set to Reset" is displayed on the DIC screen.
Step 3 of 5
Press the "set" button and hold it down until "100%" is displayed on the DIC display screen.
Step 4 of 5
Wait until three brief chimes emit before turning the ignition key back to the off position.
Step 5 of 5
Start the engine of the Aztec to ensure the oil warning light ("Change Engine Oil") is no longer illuminated on the instrument panel. If it still is, repeat the procedure.
Non-DIC (Manual Change Oil Light)
Step 1 of 4
Insert the key into the ignition and turn it to the ON/ACC position with the engine off.
Step 2 of 4
Step on the accelerator pedal fully to the floor three times within five seconds.
Step 3 of 4
Turn the ignition key to the off position.
Step 4 of 4
Start the engine to ensure the oil warning light is no longer illuminated on the instrument panel. If it is,repeat the procedure.
Aug 22, 2013 | 2003 Pontiac Aztek
Efel oil stove wont burn blue only yellow
Pull the crown and the two crown supports, scrape and vacuum the residual ash on the bottom and around the starter coil. Pull the and turn the oil feed tube scraper back out of the way. Reach inside the tube with a screwdriver and scrape out the residue until as clean as posssible. Exercise the fuel tube rod several times until there is no scraping sound. Vacuum the interior and replace the parts (Do not clean the crown).
Dec 23, 2012 | Cars & Trucks
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
Oil maintenece light is on. Oil level is good. Could a clogged filter make this light go on?
This should only be indicating time for an oil change. Now, if the red, check engine light comes on, then you have an oil/engine problem.
Possibly the maintenance light wasn't reset when the last change was done. If you don't have the owners manual to check, I found a referenced method (below) to reset it through AMSOIL synthetic oil products. Good Luck
To reset Engine Oil light. Turn the ignition key to RUN with the engine off. Fully press and release the accelerator pedal three times within five seconds. If the Change Engine Oil light is flashing, the system is reset. The light will flash for up to 30 seconds or until the ignition is turned off. If the light comes on again and stays on for 30 seconds at the next ignition cycle, it did not reset. You will need to reset the system again.
Feb 09, 2010 | Saturn L-Series Cars & Trucks
Turning of oil service light on OBD II
My recommendation is definitely in the certified sevis because if you make a wrong conection wires can spoil the main computer
Jun 25, 2008 | 1996 BMW 318
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Heating & Cooling Logo
1,277 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
