Question about AEG Washing Machines
AEG OKO LAVAMAT 86820 Update .Its dead.How can i fix it, but first, open the door without being pluged ?
  • 2 more comments
  • curto_pedro Sep 13, 2010
    Thank you for your answer , i had already discovered that part ,what i need now , is how to fix the machine, because it looks dead . Nothing is working, not even the front panel. Only if i push the water level security switch ,on the botom of the machine, i can ear the water pump working . There is nothing else working.Please help me if you can, and tell me if you understand what i wrote .Thank you.
    I don´t think you understood what i wrote , because i told you before that , when i push the security switch in the bottom of the machine the water pump starts , so theres nothing wrong with the electrical instalation or with the power cord . I don´t know what you call CCU or where to find it , i see two big control units in the bottom of the machine and another one where the selector ( turns on and off the machine and selects the program) is, and before that there is a condenser where the power cord goes and it as 230v , i have already tested it with a multimeter . I tried to be as clear as i could, i´m sory about my inglish it might be not so good.Thank you.
  • curto_pedro Sep 14, 2010
    Can you tell me where can i find the CCU in my machine .Do you have a electrical plant for these machine or a draw or something similar.
  • curto_pedro Sep 15, 2010
    I don´t find you usefull to solve yhe problem with my whasher machine so i would like to have my money back . As you said money back garanted if not satisfied.
  • 2,272 Answers
CCU means the computer control board.The CCU can also be called the main circuit board of the machine.The main circuit board is the board which controls all the other functions in the machine.All the other electric parts in the machine gets signal/command from main board to function.If main board is faulty then it will not let the command to other parts to function.But if main board is partially faulty then it will control some functions but not all.In both cases partially or complete faulty main board.The board has to be replaced.As per the fault which you have explained it indicates faulty main board,because the power cord is passing power to the machine but board is not functioning properly.----------- To get required part you can get it from partsselect.com or fron searspartsearch.com -------------. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 14, 2010
  • raj somaiya
    raj somaiya Sep 14, 2010
    For that you will have to remove the front control panel .At the back of the control panel you will access the the CCU the main circuit board.
    Thanks for keeping updated with your query.
  • AEG Master
  • 19,396 Answers
Hi.
First you need to do an emergency emptying by accessing the filter.
Follow page 34 and 32 in this manual.
If you repute the solution helpful, then please do not forget to accept the solution.
Thanks.
Ginko.
Posted on Sep 13, 2010
  • Ginko
    Ginko Sep 13, 2010
    Hi.
    If machine is completely dead with no sign of life, repair is carried testing main socket, checking fuse in power cord if power cord is fused (eg. in UK power cord is fused, most US appliances cords are not fused). Next step is testing power cord itself. This can be done reading Ohms with a multimeter on power cord, from plug to main control unit (CCU) contacts, or reading volts at CCU with power on. After power cord, on button and timer board (CCU) are tested.
    If there is no power, problem is either socket, power cord or CCU.
    Test main using a different appliance.
    If there is a fuse in power cord, replace it.
    Test power cord.
    Test on switch only if it is separate from CCU (tested reading Ohms to find out if it does open and close).
    Replace either power cord or CCU if there is no problem in the parts discussed above.
  • Ginko
    Ginko Sep 15, 2010
    The CCU is the timer board and it is located right behind the controls, inside the control assembly.
    My solution has already been refused and after receiving bad feedback the question passed to other experts.
    Bye
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
Mar 17, 2013 | AEG Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Washing Machines Logo
825 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
