Question about Motorola Mobility RAZR V3m Cellular Phone
Battery problem hi i got motorola RAZR three months back...initially i dint charge the battery for 12 hrs before using it first..i used it as it is... now i'm getting battery problem..its there for only 2 to 3 hrs.. then suddenly its getting switched off.. then again if i put for charging, it will come again.. its happening so many times.. getting switched off and on again and again can any one plz solve it
It most likely is your sim card that might have a scratch on it or the batterey where it connects to the phone so...
Posted on May 15, 2008
How long does it take to charge battery for the first time?
Depends on the battery... a "toy" battery may only need an hour or two....a motorcycle battery may need 12 hrs @ 4 - 6 amps - depending on the type of battery....a car battery may need 10 amps for a short time (4 hrs) because they come pre-filled and charged. I NEVER depend on the "charge" of a new automotive battery (of any type)..I always charge them for at least 4 hrs @ 10 amps before initial use!! ...they seem to last longer
BUT - AS a RULE = 10 hrs @ 10% of the rated amperage...
Aug 16, 2017 | The Computers & Internet
Motorola FV200R Talkabout dosent turn on
Yes, it is likely you need new battery packs. The Li-Ion batteries have a 12-18 month life expectancy. They will sometimes go longer if the radios are charged and depleted at least once a month. This style battery should be available from your local Motorola dealer on online at Motorola. http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601560
Sep 29, 2009 | Motorola TalkAbout FV200R (14 Channels)...
Motorola razor not charging..after 1 mth of use
i have one just like that. it was because i over charged it. take out your battery when mine did that the battery looked a little bowed out on both sides. the salesman called it an exploded battery
Jul 07, 2009 | Motorola Mobility RAZR V3
Motorola talkabout t5700
No, the charger is only usable to charge the rechargeable NiMH or Li-Ion battery which comes with the radio. Attempting to charge Alkaline rechargeable batteries with this charger could cause the to expode. If your charger is not charging the batteries which came with the units, it could be you do not have the charger cord end plugged in all the way, or the batteries dropped below the initial charge level by setting on a store shelf too long. Most TalkAbouts come with a cradle style charger to hold the radio, and a possible plug to plug into the charge hole. Check all connections, and clean any battery/charger contacts with a pencil eraser. To re-initialize the batteries you would need to attempt 3-5 charge cycles by charging for 8-10 hours, then letting the battery rest for 8-10 hours, repeating 3-5 times as needed. If this does not bring the battery back to life, you need to replace the batteries.
Jun 07, 2009 | Motorola Talkabout T5700 AA (22 Channels)...
We had a new battery it Razr/V3c and the phone is working but try to charged the battery and it say "unable to charged" i need to know why it not working.
hi ... i think your battery charge is gone under minimum limit ... Please try charging your mobile with another battery and try to switch on your mobile and after five min remove the battery, charge with your battery and see whether its charging or wat??
May 30, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Battery won't charge. Charger works on other Motorola phones.
More than likely the battery is done for...
I myself have so many phones that have batteries that will no longer charge or much less retain a 5 minute charge due to them being on ice for the longest time.
Best bet is to replace the battery with a new/used one.
Mar 15, 2009 | Motorola Mobility RAZR V3
Please Help !!! my Motorola RAZR V3i is automatically shutting down ...
take the phone and have the firmware reflash this should correct the issue that you are having
Jun 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
RZAR v3 battery issue
Hi
try using until the battery is dead, then recharge for 24 hrs. let me know if it working so we can do other method
Nov 20, 2007 | Motorola Mobility RAZR V3
Battery
Turn on the battery save feature and select a slow search frequency.
Nov 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
