Question about Sport & Outdoor - Others
Hi, I have a commercial grade treadmill, the Technogym Run 600XT Pro that gives the error code E5 (incline fault) that I can't get rid of. What happened was that after cleaning under the motor cover and turning the treadmill on again this code appeared. What had happened was a wire had come off what looks like a safety switch on the side which I assume trips if the treadmill goes too high. Put the wire back on now I can't get rid of this error code. Is there a way to reset it from the console please as there isn't a fault and it was working fine before the wire came off (it didn't touch anything). Thanks a lot.
  • Sport & Outd... Master
  • 19,396 Answers
Hi.
If there is incline fault, then the sensor must be calibrated. The error may happen even if you do not do anything. sensor goes out of calibration and you get e5.
The only reset you can do is by disconnecting power and removing console batteries if installed (that depends on the treadmill model).
I suggest contacting Techogim and following the procedure to calibrate the sensor. Contacts are listed at the right hand side of this page, click: Contact Us.
Posted on Sep 13, 2010
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Error code 660 & 595
Ray here, I had the same codes Icon couldn't ID them, new motor, then motor control board was troubleshot by me & my tech guy has never been the same, if it's a commercial grade unit, it starts wth a C, the motors have a lifetime warranty, so don't buy one, 9 out of 10 times it's the MCB ">
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
How do i change the language on technogym top 600 machines
use your owner manual, go to the menu, and proceed according.
or download from www.fitness.manualsonline.com
or www.retrevo.com
God bless you
Jul 27, 2013 | Sears Technogym 600xt Pro Recline...
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
Apr 13, 2013 | True Technogym Excite Run 700 Treadmill
Change language on technogym treadmil
go to the MENU and proceed with the instr. manual for to change the language.OR download the owner manual free.
go to www.fitness.manualsonline.com
God bless you
Dec 06, 2012 | True Technogym Excite Run 700 Treadmill
Hb pioneer pro treadmill gone to full incline with E6 fault code, how do i fix it
Please RUN the software calibration instruction is UNder the hood motor cover. and follow steps. this is for diagnose, troubleshooting and fix it.
then lubricate the gear and shaft elevation motor.
God bless you
Aug 05, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
Sport & Outdoor - Others Logo
430 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
