Question about Radio Communications
Faulty vhf cb radio
I currently own a uniden vhf cb radio model 013. I have power to my unit.
With the volume fully on i can hear faint voices, only if i put the speaker to my ear. Others can hear me loud and clear. Have you any ideas on how to fix this problem please. Any help with this matter would be gratefully appreciated.
Kind regards
Jamie
  • 138 Answers
I would suspect a defective audio power amp inside your radio. if you have electronics know how, disconnect the speaker and test with a multimeter for continuity just to be sure. i might just be a dead speaker.. good luck
Posted on May 15, 2008
Need a schematic for a UNIDEN HH979 VHF Marine radio.
Go direct to UNIDEN or a repair statin that services this unit
Oct 15, 2014 | Uniden Hh979 Vhf Marine Handheld Radio...
What's up I have a uniden Washington no sound out of the speaker but it is receiving you can tell by the s meter moving.?
do you have the volume turned up? Squelch turned all the way left and RF gain all the way right. If you still don't hear anything check to see if this model has a dynamic squelch .If it does turn it off.
Sep 30, 2014 | Radio Communications
No sound uniden cb radio pro501xl
make sure the RF GAIN is wide open and the squelch is turned all the way to the left . Make sure its on CB not PA ,now turn the radio on and you should at least hear something. If not ,take it to a tech and have them adjust the receive .
Nov 07, 2013 | Uniden BRVY0823001 Volume Control For...
I can,t get any modulation on my uniden pc68xl cb
you shouldn't be able to hear your modulation anyway,unless you have talkback. If you can't hear to well get a mono set of head phones or turn your radio volume up.
Mar 20, 2013 | Uniden Radio Communications
My cb radio is on but cant hear nothing sound is turn up but nothing come out
You didn't include the make / model CB you have, so I can only offer general suggestions. If these do not work, please provided the missing info.
Start out by locating and setting the the Volume to a position between 1/4 and 1/2 way clockwise, the Squelch to fully counter-clockwise and the "RF Gain" to fully clockwise to "MAX".
Check the position of the "PA / CB" switch and set to CB. When set to PA, both receive and transmit audio is sent directly to an outdoor speaker (instead of through the transmitter and antenna for reception by other radios). The PA speaker is usually connected to a jack at the rear of the radio. When the PA / CB switch is selected, the internal speaker is silenced even if there is no PA speaker connected.
At this point, you should hear static or voices (with an antenna connected). Do not attempt to transmit without a properly tuned antenna connected. If no sound is heard, there's something else wrong.
May 22, 2012 | Uniden Pc 78xl Cb Radio Mobile
I have a Midland CB Car with no mike or a car power pluge, the model # is 70 - 336B and the serial # is 760408
Your midland CB will use a standard 4 pin wired CB plug which is most common for most mics sold today. Your power cord will be a standard 3 pin CB power cord which again is most common with CB's today. You need not purchase a "radio specific" cord or mic. Cobra, Uniden, Midland all the same mic pin out and power cords. Good luck.
Feb 09, 2011 | Radio Communications
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
Uniden UH-013 squelch
Had an issue with this unit since new. Squelch adjusted too high. Not hearing some signals showing on meter. Solution - find a trim pot labelled "Meter" on the PC board and adjust it like a knobby squelch control. Made a big difference to the number of received stations. Down side is I need to use SQT tight squelch sometimes.
Feb 20, 2009 | Radio Communications
Radio Communications Logo
69 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
