Question about FUJIFILM Instax 210 Film Camera
I have a Fuji Instax 210. Now the polaroid picture won't come out from the top. I opened the back and cleaned the rolling part but it still doesn't work. What can I do to fix it? I don't know any place that can fix a Fuji Instax so I think I have to fix it myself.
The same thing happened to me. Make sure that the mechanism arm on the inside that pushes the picture up is connected with the metal piece on the right hand side. The two can come loose allowing the metal piece to not bring the arm with it when you take a picture. Also the roller could have fallen down a bit. From the inside, press the roller up (it will click when it is in the right spot). The roller should be even all the way across and pushed all the way to the top of the camera.
I hope this helps if you haven't been able to fix it already.
(When all else fails, try changing the batteries.)
Posted on Nov 24, 2010
  • 9 more comments
  • SD74 Jan 20, 2011
    Teenyvators... you have just rescued my 210 from a likely resting place in the garbage. I was going to fiddle with it a little to see if I could fix it. The roller bit was exactly my issue, and so easy to fix. It's working again!
  • yf2- May 21, 2011
    Same thing happened with me. I'm trying to fix it myself but I can't seem to figure out what the roller is, or which is the arm that pushes the picture up :/ A little help, please?
  • mamui_04 Aug 05, 2011
    how do i push the roller?
  • Jessica Tomoe Sep 16, 2012
    WOW, this just fixed my 210... Both things had happened. I had fixed the arm myself but didn't think to push on the roller. Imagine my face when I pushed up on it and heard the "click"... It works perfectly now! Thank you so much!
  • tawny256
    tawny256 Dec 12, 2012
    FIXED MINE ALSO!
  • fakie_biggie Dec 29, 2012
    The roller on mine had come loose aswell but thanks to this Its all good now! Thank you so much!
  • daphne fecheyr Jun 17, 2013
    My instal camera doesn't want to take pictures anymore. It seems like everything is working ok (lens, batteries are new, the side buttons). Even after putting in a new set of photos, there is a "-" sign on the screen, so it doesn't sensors the available photos I guess. Is this a related problem to what's been discussing here? If so, I actually don't know what the roller is?
  • Ellis Fiser Aug 09, 2013
    my 210 seems to be working fine as well but after a recemy
  • jeramiah pulsen
    jeramiah pulsen Feb 05, 2015
    what is the roller!?
  • Terri Flagg
    Terri Flagg Aug 30, 2017
    wow...my 210 has been broken and lying around the house collecting dust and cat fur for probably four years. I randomly sat down today to see if I could fix it, not expecting much. This one hundred percent fixed it. I can't believe it. It's a miracle. Thank you!
Is the flash off by default on start up? My light is not working.
Lomo'Instant Camera - Lomography
microsites.lomography.com/lomo-instant-camera/about/
LomographyThe Lomo'Instant has an auto flash shooting mode so you can easily shoot fantastic ...The default aperture value is f/16 and the exposure compensation dial can be ... Theflash is switched off and you can switch between N for normal daytime ... Close-UpLens Attachment (Included in the Camera plus Lens Packages): With ...
Fuji Instax 210 Instant Film Camera Review - Dan Finnen
danfinnen.com/review/fuji-instax-210-instant-film-camera-review/
Oct 2, 2013 - Here is a line of instant cameras that are still manufactured new and use film ... using the camera, mostly because your hand is already covering it up. ... Other controls include a lighten/normal/darken switch and a flash on/off button. ... Heck, if the camera didn't default into macro mode that would make the ...
Fujifilm Instax Mini 90 - Instant 'Polaroid' camera - PhotoMadd
photomadd.com/fujifilm-instax-mini-90-instant-polaroid-camera/
Jan 11, 2016 | Photography
Battery charger for a baobeng v82
The manufacturer/distributor might be able to supply one.
Apr 28, 2014 | Fuji Instax 210 Wide Polaroid Camera 80...
Fuji working wont power up
Make double sure you are putting the batteries in in the right direction.
Dec 03, 2013 | FUJIFILM Instax 210 Film Camera
Instax 210 makes funny noises and doesn't spit out the film
Hi try getting in touch with polaroid or fuji via their website! My camera does the same thing (though its an instamax)!
Aug 27, 2013 | FUJIFILM Instax 210 Film Camera
I put a fresh new pack of film into my Fuji film instax 210 camera but only used it to take two pictures. The next day when I tried to take a picture, it came out completely white. Why is that? It is very...
Completely white photos on an Instax, or any instant camera means the film has been exposed somehow. Check to be sure the film door is completely closed, and latched properly. If it is, it's possible, though unlikely, that your camera's shutter is stuck open. It'd be easy to check, simply look at the front of your camera into the lens, and see if you see any mechanical bits, now take a picture and see if you see any of them move - movement means working, no movement means not. If the entire camera back opens (I'm not sure if it does) you can also open it and do the same thing, looking to see if you see light through the camera when you're looking through the lens but not taking a picture - if you do the lense is stuck open. This, however, would require removing and wasting whatever film is remaining in it right now.
Aug 30, 2011 | FUJIFILM Instax 210 Film Camera
Does fuji ins tax film work in Polaroid 300?
No. They are totally different and incompatible systems, sorry.
Aug 04, 2011 | Polaroid Photography
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
My fuji instax mini 7s has an error message on the screen. It blinks "E" and does not allow me to take any pictures. The instructions and manuals that came with package are all in japanese and i...
Firstly, remove the remaining films in your camera (while the camera is switched off) Secondly, switch on the camera. Press the power button and the shutter button simultaneously at one go. (to reset) Thirdly, reload a new set of polaroid films. Hope it helps!
Nov 05, 2010 | Fuji instax mini 7S Film Camera
FUJIFILM Instax 210 Film Camera Logo
8,483 people viewed this question
Top FUJIFILM Photography Experts
jairo sanchez
 steve
steve
Bill Boyd
Are you a FUJIFILM Photography Expert? Answer questions, earn points and help others
