Question about D-Link DCS-5220 Network Camera
How to setup aztech router for remote ipcamera (dlink dcs-5220 model)
    Guru:
  • 551 Answers
Install the installation disk of the ipcamera. Configure the ipcamera base on your requirements. Then install the ipcamera on the position you require.
Posted on Sep 13, 2010
How to recover corrupted firmware for IP camera DCS-5220?
http://support.dlink.com/ProductInfo.aspx?m=DCS-5220
Go to this site and download the drivers
Then
Uninstall old drivers and install new ones
Jan 06, 2017 | D-Link DCS-5220 Network Camera
I am trying to install the dlink dcs 5220 camera, i have connected the camera to the router and the installation software has detected it. But everytime i click 'setup' all i get is a 'connection...
Welcome to Fixya
Try to uinstall and reinstall the software. Ping the camera if you are getting a reply. Reset the camera by pressing the small hole on the side. If everything is already done then same thing occur then you have a defective camera.
Thank you for using Fixya!
Apr 17, 2011 | D-Link DCS-5220 Network Camera
I can not see anything in iphone with DCS 5220
Go to Setup and make sure ALL of the ports are conigured and port forwarding is setup for these ports in both your modem and your router
Dec 22, 2009 | D-Link DCS-5220 Network Camera
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
D-Link DCS-G900 Network Camera setup
http://www.dlink.com/products/?pid=270
go here and on the right under support resources select application.
Aug 12, 2008 | D-Link DCS-G900 Network Camera
DCS-1000w through Dlink DIR-655 router
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
Apr 12, 2008 | D-Link DCS-1000W Personal Web Camera
Inability access from other computers
You need to check with your router vendor on how to setup DMZ or Port Forwarding for your DCS-5220 in your router. (For Port Forwarding, please open BOTH HTTP Port and RTSP Port and select the Protocol as TCP for HTTP Port and select the Protocol as TCP/UDP(Both) for RTSP Port.
Nov 14, 2007 | D-Link DCS-5220 Network Camera
D-Link DCS-5220 Network Camera Logo
529 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
