Question about 2wire (1000-000057-000) Modem
My modem (2wire 2071-A) was working fine yesterday and now I can't connect, the power light and dsl light are both on and I have connected my ip (tpg) and they said the my connection is fine they got me to try and check the setting via gateway.2wire.net but that didn't work so I was informed it my be a manufacturing problem, I thought this was odd swing as it was working fine less than 24hrs ago! What could the problem be?? Matthew
kiboiz
  • 6 Answers
SOURCE: Intermittent DSL connection
hi, i happen to be one of the technical support agent of this dsl modem/router..it's very simple...there are a lot of factors that may cause the intermittent connection...one could be the filter if it's hard wired, or EMI's... or defective ethernet cable...however, if it's wirelessly connected to the computer...there could be problem like slow browse, no browse or no connection at all if there's a wrong configuration of the modem...
Posted on Dec 29, 2008
SOURCE: How to configure Modem 2Wire 2701-A ADSL
dont use to this modem
Posted on Jan 23, 2009
dante777
  • 623 Answers
SOURCE: 2wire 2701HGV-W Gateway wi-fi modem
The 8200 by itself does not have networking capability.
This means that you cannot connect it directly to your router and give it an IP address, so others can connect to it.
The good thing is, that this printer is listed on the list for compatibility for upgrade with the wireless network kit (see here). The bad thing is - this kit costs about 70$ (see here).
A solution which does not cost anything, is to share the printer from your computer with the other computers. The downside is that the machine to which the printer is connected has to be running in order to let the others print.
If you decide to buy the Networking Kit - here are the setup instructions.
Sorry - but there is no simple (plug & pray) solution.
Posted on Feb 13, 2009
c_robertson
  • 123 Answers
SOURCE: I need manual installation instructions (dont have
It appears to be a DSL modem. You don't need a driver, but a username and password for your internet provider. Here is how you install.
connect to phone line then usb or network port (drivers should be built in xp) open your internet browser and type 192.168.1.1 to open the internal web page. It should step you through the username (email address) password. Must ask your internet provider for those.
Posted on Apr 29, 2009
  • 31 Answers
SOURCE: connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
Posted on May 20, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
2-wire modem won,t come up in connections,and don,t know how to configure modem dsl light solid green and can,t find lan settings,it,s a 2071-a
If you know your local network address side address then just log into the 2Wire with "http.XXX.XXX.XXX."
Example my 2Wire: "http.192.168.1.254." I'm not sure but I think the 192.XXX.XXX address is default.
The box has a little web server that will allow you to reconfigure to default but if your provider programmed it you may need info from them.
Sounds like the DSL side is working.
Oh, if you have the info from your provider to set it up, you might have to push the reset button on the box to reset it to factory default.
Then it gets a little complicated.
Nov 18, 2009 | 2wire Computers & Internet
I got d-link dir-615 wireless router and a 2wire modem 2071-a and when i set up the d-link router my desctop computer that is pluged into d-link cant get internet im 11 and got no idea wat to do oh and the...
does the computer that's directly connected to the modem connect to the internet? If not then make sure your settings are well set, your service provider (ISP) and all the other settings that your ISP supplied you have not been tempered with or modified.
Does you WDS and router communicate? Have you changed the IP addresses form the default ones that came with your devices? They usually begin with 192.. at times the default IP addresses don't work in some institutions. You can configure most DLinks using internet explorer by typing in the DLink IP address bar.
Considering your age, you need someone to show you how these things are done.
Aug 24, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
I turned off the power to my 2wire box - now I can't get it to power up and have internet. What do I do??? More details: I had turned off the surge protector the 2wire box is connected to - when I turned...
Hi there!. unplug the power plug of your 2wire box from the surge protector for 1minute and after 1 min, plug in directly to the wall outlet, not to the surge protector. try to unplug and replug as well the connection on the back of your 2wirebox and check the cable connection from the isp cable to the modem,, the last option that your going to do is to reset the modem of your modem/router but make sure that you know the settings of your modem and wireless settings if u have.. or contact your isp provide for further details..there is a situation that there is a problem from your dsl company connection, most dsl use telephone lines..
Aug 14, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I have a 2wire 2071 - A modem and it wont read my ethernet cable
First check device manager to see if the copmuter recognizes the card, if it dont use the add hareware app, and have windows plug &play try to locate it. then open the case and remove the card with windows running and replace it in the slot , P&P may then locate it if windows doesnt, then the ethernet card may of had a voltage spike go thru it and fried the card.
Jul 12, 2009 | Computers & Internet
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-000057-000) Modem Logo
152 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
