Question about Peg Perego John Deere Gator HPX Ride on Toy
Put a new fully charged battery in the tractor and replaced the 1st, 2nd speed gear switch but still no go . any idea,s
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Posted on Jun 13, 2012
  • 9 Answers
SOURCE: Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Posted on Feb 17, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Posted on Jul 08, 2010
  • 12 Answers
SOURCE: Our childrens gator has had a new battery and
the answer is it is the transmission 1st and reverse are the same gear on any vehicle it will have to come out and come apart dont worry if you dont know how if can do this once apart you are looking for a shifting fork that looks simular to a tunnig fork if you cant order parts a new trans or used trans will fix it or do what i do dispose of it.
Posted on Nov 21, 2010
3 speed box in drive 1st and 2nd gear takes 3rd gear dont
How to adjust 3 speed column shifter - YouTube
? 9:53
https://www.youtube.com/watch?v=2TCHzIvAvRQ
Mar 6, 2014 - Uploaded by luke Fugate
This is a video to show you how to adjust a Three speed on the column to ... It's great not having to wind the engine and transmission just to take off in 2nd or 3rd gear. ... It was ALWAYS getting stuck between 1st and 2nd gear. .... 1977 c10 3 On The Tree ' How to Drive a 3 Speed Column Shift - Duration: ...
Diagnose Automatic Transmission
www.aa1car.com/library/2002/bf90222.htm
All they know is that they put their gear selector in "D" for Drive and their vehicle ... But when internal problems cause the transmission to act up, it takes a fair amount .... In Chrysler three-speed automatics, changing the fluid to ATF+3 can also help ...kickdowns to get the transmission to downshift to 1st from 2nd or 3rd gear.
Manual transmission - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Manual_transmission
Wikipedia1 Overview; 2 Unsynchronized transmission; 3 Synchronized transmission; 4 Internals.... gear speeds by blipping the throttle when shifting from 2nd into 1st. ... In a synchromesh gearbox, to correctly match the speed of the gear to that of the ... Even in transmissions that do not feature direct drive, it's an advantage for the ...
When do you use the 1,2,3 gears on an automatic car ...
https://www.reddit.com/.../when_do_you_use_the_123_gears_on_..
Jan 10, 2016 | Cars & Trucks
Lawn Tractor will not start
check for power at the solenoid then put power to the small terminal at the solenoid and see if that turns it over then check the the safety switches
May 20, 2012 | John Deere Garden
Battery light came on a couple of days ago. Last night it started and as it was going the radio stopped working and the engine was reving as if stuck in 2nd gear. After shutting off the van it would not...
problem on battery light came on, loose belt tension. power is out so all part will not work. and check the battery again, make sure it was fully charge.
Jan 30, 2011 | 2001 Chrysler Town & Country
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
!st gear won't work
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
