Question about Sharp AL 1631 Copier
How do I remove and install the "drum" on my copier? Drum light is on and I replace my cartridge toner. Drum light is still on.
  • 1,110 Answers
If your copies are fine just reset the drum unit counter. To reset the drum light, press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
Posted on Sep 13, 2010
Testimonial: "Drum light was turned off. Mahalo for your help."
  • davite01 Oct 07, 2010
    thank you for your help
4 Suggested Answers
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
vmachlis
  • 7 Answers
SOURCE: Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Posted on Dec 21, 2008
  • 114 Answers
SOURCE: 'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Posted on Mar 21, 2010
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Why it prints grey background
Either the toner cartridge is very close to empty or the drum unit needs to be replaced. Check your warning lights. Yellow = toner, red = drum. If no warning lights, pull out the toner/drum unit and remove the toner cartridge. Have a look at the cylinder in the drum (DR2125) - if it is very black and matt looking you will need to have it cleaned or just replace it.
May 20, 2014 | Brother HL-2170W Laser Printer
How to replace drum?
Replacing the drum on these machines is pretty simple. Leaving the power on, open the hatch at the front and remove the toner/drum assembly inside. You may need to lift it slightly then pull toward youself firmly. The toner cartridge sits inside the drum unit. Depress the green tab on the left corner and lift the toner cartridge out. Transfer the toner cartridge to the new or rebuilt drum (DR2125), press it firmly in to place. Return the drum/toner assembly to the printer, pushing it in as far as it will go. Press and hold the red stud left hand side in line with the lights until ALL the lights are on. Then release the stud and close the front hatch. and you have replaced the drum and reset the drum page count. The machine should then have only the blue ready light on
Oct 30, 2013 | Brother HL 2140 Laser Printer
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
Hi - These HL-5250DN Drum light comments are great but I cannot even find where the drum IS within my printer to take it out, replace it. Can you help? Thanks
Open the front door and pull the toner/drum cartridge out of machine. Remove the toner cartridge from the drum unit by pressing a lever. This will leave you an empty drum unit and a seperate toner cartridge.
May 11, 2011 | Brother Office Equipment & Supplies
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
I have a brother HL 2040 laser printer. The toner and drum light were lit, so I replaced both the drum and the toner cartridge, but the toner light remains on. I have tried everything, but the toner...
Two things I could suggest you check. First, make sure you have removed all packing from the drum and toner. Sometimes there is a plastic strip on the toner that has to be removed before installation. Also, make sure you are using a Brother brand toner. Some generic brands do not replace the chip in the cartridge and they will not work,
Sep 19, 2008 | Office Equipment & Supplies
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Oct 25, 2007 | Brother HL-2040 Laser Printer
Sharp AL 1631 Copier Logo
212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
